Kelsenellenelvian Posted September 20, 2006 Posted September 20, 2006 INSTRUCTIONS FOR GIVING A CAT A PILL1. Pick cat up and cradle it in the crook of your left arm as if holding a baby.Position right forefinger and thumb on either side of cat's mouth and gently applypressure to cheeks while holding pill in right hand. As cat opens mouth, pop pillinto mouth. Allow cat to close mouth and swallow.2. Retrieve pill from floor and cat from behind sofa. Cradle cat in left arm andrepeat process.3. Retrieve cat from bedroom and throw soggy pill away.4. Take new pill from foil wrap, cradle cat in left arm holding rear paws tightlywith left hand. Force jaws open and push pill to back of mouth with rightfore-finger. Hold mouth shut for a count of ten.5. Retrieve pill from goldfish bowl and cat from top of wardrobe. Call spouse fromgarden.6. Kneel on floor with cat wedged firmly between knees. Hold front and rear pawsfirmly. Ignore low growls emitted by cat. Get spouse to hold head firmly with onehand while forcing wooden ruler into mouth. Drop pill down ruler and rub cat'sthroat vigorously.7. Retrieve cat from curtain rail. Get another pill from foil wrap. Make note to buynew ruler and repair curtains. Carefully sweep shattered Doulton figures from hearthand set to one side for gluing later.8. Wrap cat in large towel and get spouse to stretch out flat on top of cat withhead just visible from below arm-pit. Put pill in end of drinking straw. Force mouthopen with pencil and blow down drinking straw.9. Check label to make sure pill is not harmful to humans. Drink glass of water totake taste away. Apply Band-Aid to spouse's forearm and remove blood from carpetwith cold water and soap.10. Retrieve cat from neighbor's shed. Get another pill. Place cat in cupboard andclose door onto neck to leave head showing. Force mouth open with dessert spoon.Flick pill down throat with elastic band.11. Fetch screwdriver from garage and put door back on hinges. Apply cold compressto cheek and check records for date of your last tetanus shot. Throw tee-shirt awayand fetch new one from bedroom.12. Ring fire brigade to retrieve cat from tree across the road. Apologize toneighbor who crashed into fence while swerving to avoid cat. Take last pill fromfoil-wrap.13. Tie cat's front paws to rear paws with garden twine and bind tightly to leg ofdining table. Find heavy duty pruning gloves from shed, force cat's mouth open withsmall spanner. Push pill into mouth followed by large piece of filet steak. Holdhead vertically and pour pint of water down throat to wash pill down.14. Get spouse to drive you to the emergency room. Sit quietly while doctor stitchesfingers and forearm and removes pill remnants from right eye. Stop by the furniturestore on way home to order new table.15. Arrange for SPCA to find a new home for cat and ring local pet shop to see ifthey have any hamsters.={^:^}= Meow-hahahahahahahahahaha Quote
ricktendo Posted September 20, 2006 Posted September 20, 2006 YIP!!!If you think thats bad try giving him a bath Quote
