For years I have ripped the few good songs from my CDs onto my HDD and named them manually. My format is "Artist - Track Title.mp3" None of these are arranged in album order; I just dump all the Rock songs into a folder named Rock, for example. This process always worked well since I never processed more than a few songs at a time.
But now I have quite a collection built up and want to use them in my media center.
The media center can do lots of neat stuff with music once it is properly tagged. But I have no tags. I have managed to use software like The Godfather to batch process my filename data into proper tag data. But that doesn't include the album or any other neat info like the year or genre.
I'd like to find a tool that will batch process my files to retrieve at least the album title and genre from FreeDB based on just the artist and title found in the file name. Additional data would be nice, too. I anticipate needing to manually approve each album title selection from a dialog since one track can be found on multiple albums. Haven't had much luck so far with Godfather, ID3 Renamer, Tag&Rename, AudioGrail, MediaTagger or ID3Sync.
Any suggestions on another tool to use, or tips on how to use one of these tools to do what I want?
This question is cross-posted from MSFN. Hope that is OK.
Same problem here, but haven't found the way to tag all of my files.
I presume that cygnus will help us since he tagged all of his MP3 collection..
I don't mean to drive traffic one way or another, but thought you'd like to know that this question got aswered on MSFN. The thread is here. Cheers!
  • 5 months later...
Posted (edited)
Hello guys,
I've been searching long time ago for such a thing, and unfortunately didn't get any good result.
Finally I've found a very simple way that I didn't notice in Winamp
As a matter of fact this amazing media player has a built-in service called "Auto-Tagger"
and this service comes from GraceNote.com
Anyway, when you need to auto-tag your music files you just have to do this:
*For a single file auto-tag: Just view the file info by pressing ALT+3 keys, then in the "Basic Info" tab you'll see on the bottom right
a button called "Auto-Tag"... Just click on it and see what you'll get next!!!
*For multiple music files auto-tag: Select whatever you want in your playlist, then right click on them
Select The "Send to" submenu, then "Auto-Tag".... A new window will appear with your files that you've selected, wait for for a while
and see what will happen to the ID3-Tag, you can also compare between the old and the new information...
I think that it's easy and simple just like 1-2-3! ;)
Hope that it'll be useful
Edited by -=CoDeM@StEr=-
Is this a plugin? I don't see the options you are talking about by default. What version of WinAMP are you using?
Since we're discussing winamp here, does anyone has problems with album arts. Winamp always shows completely wrong album covers while playing songs?? :unsure:
Hey, I'm so interested in Winamp, I hope that I can help you as much as I can
Regarding the album art problem I can give some tips that might help you
as I said I'm using the version 5.52 and that's pretty nice ^_^ , so when you get the wrong album cover press ALT+3 to view
the song info, then select the "Artwork" tab just like in this pic:
if it was the wrong one you can delete it, then you have to pick your choice, either Download Art, Load Artwork or Paste Artwork
now sometimes winamp doesn't download the right album cover, and when I find that there's no match when trying to download
it from winamp I simply search for the cover over the internet, in google for example, and save it to my PC...
then I choose Load Artwork, now it's done! and don't have to do this many times for the rest of the files if there were in the same album,
winamp will load it automatically for the whole album.
Musicmatch was the best for that, but since damn Yahoo! got it long ago, the service stopped working.
I searched a similar replacement, and MediaMonkey is now my way to go, it search Amazon Music for the info, being Artist, name of the song, Album Art, etc...
With it I've been able to organize close to 3500 mp3s that I had on my temp folder easily.
I hope it helps.
MediaMonkey's Homepage
