RegSeeker v1.55
www.hoverdesk.net/freeware.htm
RegSeeker 1.55:
RegSeeker is a perfect companion for your Windows registry !
RegSeeker includes a powerful registry cleaner and can display various informations like your startup entries, several histories (even index.dat files), installed applications and much more ! With RegSeeker you can search for any item inside your registry, export/delete the results, open them in the registry. RegSeeker also includes a tweaks panel to optimize your OS ! Now RegSeeker includes a file tool to search for duplicate files, bad shortcuts and more !
RegSeeker is FREE for personal use only !
Daemon Tools Lite 4.10 (with SPTD 1.50)!
So far, I could only find version 4.09.1 (with SPTD 1.50), but no AddOns for 4.10.
Apparently, from reading the threads over at Ryan's, the SPTD is especially tricky, hence I haven't dared creating one myself (I have succeded in doing so several times before but that were rather moderate ones ;)).
Hence, this one would be very appreciated :D
Also, if you still got enough times, why not also Deamn Tools Pro?
I'm just not sure how the licence key situation would work out on that...
YOu can find one Here on RogueSpear's Forum... Hope it can help you Helmi. :icon_cool:
Only good at INF addons not those switchless ones that use CMD files and RunOnceEx
EDIT: Found one but you may need to register http://www.doitrightconsulting.net/forum/viewtopic.php?t=120
Thank you so much!
I'm already registered at RougeSpear's forum (I really like his other nLite and DriverPack tools =)), so that's the least issue of mine ;)
Once again, you made my day, Rick.
Cheers!
this addons l need dont find enyware
1.
2. install_flash_player
3. jre-1_5_0_05-windows-i586-p
4. Clear History 1.9
5. DirectX 9.0c
6. iTunes 7.0.2
7. iview
8. mplayer_extra_codecs
9. Nero-6.6.1.4
10. Uninstall Tool 1.6.6
11. winamp535_full
12. XP Codec Pack 2.0.8
13. LimeWireWin
tks
Adobe Reader http://www.msfn.org/board/index.php?showtopic=88167 (this is a silent switch installer, you may have to make a addon out of it)
Flash http://picsbook.net/shark007/index.html (you can download it and make it silent using the /Silent switch)
DX9 Nov http://www.ryanvm.net/forum/viewtopic.php?t=5239
Java update 3 http://www.ryanvm.net/forum/viewtopic.php?t=3850
LimeWireWin au3 launcher http://www.mediafire.com/?3x011jmmb43 (just place in the same dir as LimeWireWin.exe and make sure you have installed java, you can also create a addon by 7ziping it together with the installer)
Nero 6 with NCAB http://www.msfn.org/board/index.php?showtopic=44603
Orbit Downloader 2.4.2
Homepage
Orbit Downloader V2.4.2 ( Nov 6, 2007 )
* Improve: install interface
* Fix: the bug which may cause orbitnet can not be exit
Download
Appreciate you taking the time to take requests..... :thumbsup_anim:
Edited by Makave2345
1. Registry Mechanic (new v7)
2. Registry Booster
3. Combined Community Codec Pack
4. Newest Power Archiver
5. SpyBot Search and Destroy
Thank You! :crying_anim02:
Edited by MichaelBX
