Genuine Advantage AddOn
Info: This addon can be integrated with the RVMUpdatePack, it contains Windows & Office Genuine Advantage also Microsoft Update Catalog Web Control and Microsoft Office Update Detection Engine ActiveX Controls
tabdownload.png Updated April 11-2008
MD5: 0FF0B701A47EA97455E8A1C7B12432B7
Website: http://www.microsoft.com/genuine/downloads/WhyValidate.aspx
File Versions
LegitCheckControl.dll ................. 1.7.69.2
MicrosoftUpdateCatalogWebControl.dll .. 7.0.6000.569
OGACheckControl.DLL ................... 1.6.28.0
opuc.dll .............................. 12.0.5557.1000
WgaLogon.dll .......................... 1.7.18.7
WgaTray.exe ........................... 1.7.18.7
Changelog:
3-30-08
- ModifiedPE all the files (trying to fix opuc.dll copy error)
3-30-08
- Updated LegitCheckControl.dll, MicrosoftUpdateCatalogWebControl.dll, OGACheckControl.DLL and opuc.dll
1-12-08
- Removed spmsg.dll
12-11-07
- Silent update, modified opuc.dll with PEChecksum this time (by n7Epilson)
12-11-07
- Added kb892130.cat and wganotify.cat
- ModdifiedPE the checksum of opuc.dll (hopefully this fixes the copy error)
12-03-07
- Added WGA Notify to addon
11-07-07
- Updated opuc.dll v12.0.5543.1000
- Added opuc.dll = 16 to TXTSETUP.SIF [FileFlags] to stop copy error
  • Replies 83
  • Views 49.8k
how to know if this addon actually works :huh:
When you got to MS Update, Office Update, Office validation, MS Update Catalog and you aren't prompted to install anything before you continue, validation should succeed
oh...guess mine doesn't works then cos at MS Update i was prompted to install active x control :confused02: Is it ok to integrate this addon using nlite :)
Edited by Mann41
Hi ricks.Thanks for the addon.
I have problem using your addon. After format the computer, computer will copy those files that need for installation. But error occur when copying file opuc.dll. Message said error when copying this file. I try to intergrate this addon again but still the same
I have the exact same problem as yadzil......
Its not a burning problem or anything.... Because I can copy the file from the disc with no problem.... But for some
reason, everytime during setup it gives a copy error..... :g:
Yeah... I use the integrator....
I just copied the opuc.dl_ file from the I386 directory on the cd thats been giving the error,
expanded it, and compared the hashes between it and the one I just extracted from your addon.....
The hashes match...... Now I'm even more confused.... lol
Yup...same with Makeve2345...using Intergrator. Initially I thought the download file is corrupt but its not. Only opuc.dll cannot be copy
I added this to my entries_*.ini, this is done in the case you get this copy error
[txtsetup_fileflags]
opuc.dll = 16
Still gives the same copy error during setup......
I'm going to try using just this addon in NLite and all my other addons using RVM Integrator......
Will post back later and let you know how it goes....
Did you able to install this addon with nLite?
Slipstreamed ONLY this addon with NLITE... And then my others with the Integrator......
Does not give a file copy error anymore, but I'm still not sure it works correctly,
because the first time I go to Microsoft Update, I have to install the Active X control before I can
do anything......
