LUZR4LIFE Posted October 21, 2007 Posted October 21, 2007 Ok. I am now using Vista and when I go to finalize a XPCD shuts down. Is NLite not compatible with Vista? Quote
LUZR4LIFE Posted October 21, 2007 Author Posted October 21, 2007 Can you use Vlite for creating XP CD's? Quote
anonymous Posted October 21, 2007 Posted October 21, 2007 nLite runs under Vista but some users have had problems.Heres one thread and another. Quote
LUZR4LIFE Posted October 21, 2007 Author Posted October 21, 2007 Thanks. I actually replied on the second link earlier. I may just have to uninstall all my security one at a time and check to see if it is that. Quote
Dave3737 Posted November 1, 2007 Posted November 1, 2007 i had this problem too so i run nlite on sp2 which i run in vmware on vista ultimate works well just a bit of mucking around transfering files , but a man got to do what a mans got to do works for me :thumbsup_anim: Quote
LUZR4LIFE Posted November 1, 2007 Author Posted November 1, 2007 LOL. I had no luck so I just started to use it inside VMWare. Just annoying a little but it gets the job done. Quote
foxxx428 Posted November 1, 2007 Posted November 1, 2007 i had this problem too so i run nlite on sp2 which i run in vmware on vista ultimate works well just a bit of mucking around transfering files , but a man got to do what a mans got to do works for me :thumbsup_anim:And then you run vmware inside of XP to run linux on right? Seriously though, I had trouble with the media player slipstreamer on Vista too so unless you have a spare XP machine, crazy as it sounds, that's the only option. Quote
