Posted November 4, 200717 yr OK... this is my first attempt at making a true addon....I decided to try a screensaver addon first......(This screensaver is a little different from the norm...It has 2 files for it.. 1 is a normal .scr file and the other is a .exe file) Both files need to go in the system32 dir....)And this also requires a User Name and serial #...I used Ricks Vista Screensavers addon as sort of a guide.....I would like someone to check my .ini and .inf files and tell me if this looks ok....I compressed both the .exe and .scr files inside CoralClock.cabCoralClockSCR.inf;ricktendo64[Version]signature="$Windows NT$"[Optional Components]Coral Clock 3D ScreensaverMyRegTweaks[DefaultInstall]AddReg =REGEntries.AddRegOptionDesc="Coral Clock 3D Screensaver"Tip ="Coral Clock 3D Screensaver"Modes =0,1,2,3CopyFiles =SCR_Files[Coral Clock 3D Screensaver]OptionDesc="Coral Clock 3D Screensaver"Tip ="Coral Clock 3D Screensaver"Modes =0,1,2,3CopyFiles =SCR_Files[SourceDisksNames.x86]1="Coral Clock 3D Screensaver Files","CoralClock.cab",,"i386"[DestinationDirs]SCR_Files = 11[SourceDisksFiles]Coral Clock 3D Screensaver.exe =1Coral Clock 3D Screensaver.scr =1[SCR_Files]Coral Clock 3D Screensaver.scrCoral Clock 3D Screensaver.exe[MyRegTweaks]OptionDesc ="Registry Entries"Tip ="Registry Entries"Modes =0,1,2,3AddReg =REGEntries.AddReg[REGEntries.AddReg]HKLM,"SOFTWARE\3Planesoft\Coral Clock 3D Screensaver","SerNum",0x0,"3: xxxxxxx-xxxxxxx-xxxxxxx-xxxxxxx-xxxxxxx-xxxxxxx"HKLM,"SOFTWARE\3Planesoft\Coral Clock 3D Screensaver","RegName",0x0,"3: xxxx xxx xxx"Entries_CoralClock.ini;==============================================; Coral Clock 3D Screensaver Add-On by Reaper |;==============================================[general]builddate=2007/11/04description=Coral Clock 3D Screensaver.language=Multilanguagetitle=Coral Clock 3D Screensaverversion=1.0.0.5website=http://www.3planesoft.com/pages/coralclock.html[sysoc]Coral Clock 3D Screensaver=ocgen.dll,OcEntry,CoralClockSCR.inf,HIDE,7[dosnet_files]d1,CoralClockSCR.infd1,CoralClock.cab[txtsetup_files]CoralClockSCR.inf = 100,,,,,,,20,0,0CoralClock.cab = 100,,,,,,_x,,3,3[i386_compress]rvmtemp\extracted\CoralClockSCR.infPlease let me know if there is anything I need to change, or any suggestions you may have...Thanks for your help on this. I really appreciate it...
November 4, 200717 yr OK lemme explain a little of what stuff doesThis section tells windows setup what section the instructions to install are, so it will look for the [Coral Clock 3D Screensaver] and the [MyRegTweaks] section (Delete MyRegTweaks from this and rename the [MyRegTweaks] section Coral Clock 3D Screensaver, also copy the AddReg from it)[Optional Components]Coral Clock 3D ScreensaverMyRegTweaksRename your .inf and .cab archive to be 8.3 filename compliant CoralClock.cab to CrlClock.cab or somethingother than that it all looks good[Version]signature="$Windows NT$"[Optional Components]Coral Clock 3D Screensaver[DefaultInstall]AddReg =REGEntries.AddRegCopyFiles =SCR_Files[Coral Clock 3D Screensaver]OptionDesc="Coral Clock 3D Screensaver"Tip ="Coral Clock 3D Screensaver"Modes =0,1,2,3AddReg =REGEntries.AddRegCopyFiles =SCR_Files[SourceDisksNames.x86]1="Coral Clock 3D Screensaver Files","CrlClock.cab",,"i386"[DestinationDirs]SCR_Files = 11[SourceDisksFiles]Coral Clock 3D Screensaver.exe =1Coral Clock 3D Screensaver.scr =1[SCR_Files]Coral Clock 3D Screensaver.scrCoral Clock 3D Screensaver.exe[REGEntries.AddReg]HKLM,"SOFTWARE\3Planesoft\Coral Clock 3D Screensaver","SerNum",0x0,"3: xxxxxxx-xxxxxxx-xxxxxxx-xxxxxxx-xxxxxxx-xxxxxxx"HKLM,"SOFTWARE\3Planesoft\Coral Clock 3D Screensaver","RegName",0x0,"3: xxxx xxx xxx";==============================================; Coral Clock 3D Screensaver Add-On by Reaper |;==============================================[general]builddate=2007/11/04description=Coral Clock 3D Screensaver.language=Multilanguagetitle=Coral Clock 3D Screensaverversion=1.0.0.5website=http://www.3planesoft.com/pages/coralclock.html[sysoc]Coral Clock 3D Screensaver=ocgen.dll,OcEntry,CrlClock.inf,HIDE,7[dosnet_files]d1,CrlClock.infd1,CrlClock.cab[txtsetup_files]CrlClock.inf = 100,,,,,,,20,0,0CrlClock.cab = 100,,,,,,_x,,3,3[i386_compress]rvmtemp\extracted\CrlClock.inf
November 6, 200717 yr Author OK.... Thanks for the help..... :thumbsup_anim: Edited December 18, 200717 yr by Makave2345
