As you may or may not have known, wincert.net used to have a series of custom bb code images that dealt with a really cool way to display download links, screenshots, etc etc.
Well now there back! and better than ever!
They are as follows:
Typing
[shot]http://(your link here)[/shot]
Without the "( )"
Will render:
Typing
[dl]http://(your link here)[/dl]
Without the "( )"
Will render:
Typing
[home]http://(your link here)[/home]
Without the "( )"
Will render:
Typing
[src]http://(your link here)[/src]
Without the "( )"
Will render:
Please report any problems you encounter with them in this topic, thanks
--- WinCert Administration Team
Please note:
*You MUST include "http://" (without the quotes) before all links or they will direct to the WinCert server and you will receive a "404 File not found" error.
*Glass effect on images may differ in appearance depending on the skin you are using.
Nice job Wolf, thx :thumbsup_anim:
It's important to mention, custom bbcode used so far will break if you try to edit old posts now..
For instance, if you use BBCode now in a new post, you'll be able to edit it without any problems, no matter how many times you try, but if the custom BBCode will be edited in ACP after you made post, during the post edit BBCode will break.
I reported this to IPB and waiting for the fix. So the best way now is NOT to touch BBCode through ACP (Wolf or me) :D.
If BBCode is finally finished, don't touch it anymore Wolf.. :crying_anim02:
I reported this to IPB and waiting for the fix. So the best way now is NOT to touch BBCode through ACP (Wolf or me) :D .
I've tested it many times, it doesnt break anymore. No matter how many times you edit :)
