Z-Info 1.0.45.32 Repack
Z-Info is a set of four (4) programs for analyzing the hardware of your PC.
SSD-Z  is a utility for owners of solid-state drives, with which you can easily find out the firmware version of your SSD drive, serial number, production technology used, detailed information about the controller, capacities, SMART indicators, TRIM status, temperature and supported interfaces, capacity and operating time from the moment of switching on. The program also has a Benchmark function, which makes it possible to test the disk. In addition, the program can recognize traditional HDDs and optical drives.
CPU-Z  is a utility that will provide you with the most detailed information about the processor, memory, cache and motherboard installed in the system. The program is small in size, conveniently displays information about components, and supports almost all types of processors and motherboards.
GPU-Z is a convenient program with which you will get as much information as possible about the video card and its graphics processor. The application will help you find out what model of video card you have, determine the connection interface, determine which GPU it is based on (BIOS version, chip revision number, frequency in 2D, 3D modes and overclocking, information about DirectX support and other useful information). In addition, the program provides information about video memory (type, size, bus width).
PCI-Z  is a utility designed to identify unknown devices that are connected via the PCI, PCI-E or PCI-X bus. The utility will display the device type, manufacturer, serial name, as well as information about the installed driver and its correct or not configuration. If the device is not detected by the system, then PCI-Z will identify it by ID using the built-in database with an extensive description of various devices. The database is updated automatically or manually; according to the developers, new devices are added to the list every day. Having further identified the device, you can easily find the required driver through the PCI-Z context menu and bring the previously unidentified device into working condition. The program also allows you to export a list of devices with a description to a file in *.TXT, *.CSV or *.jSON formats.
Features Repack
1.  Installation of programs or unpacking of portable (PAF) versions combined in one distribution package
2.  The assembly includes: CPU-Z 2.09.0(en/ru), GPU-Z 2.59.0(en/ru), PCI-Z 2.0(en), SSD-Z 16.09.09(en/ru)
3.  Optional installation the one from the programs and all at once
4.  Optional installation English or Russian programs versions
5.  Optional installation of installable programs in the Control PanelChanges: 1.0.45.32
• Added CPU-Z 2.11 (en/ru)
PCI-Z : https://www.pci-z.com
SSD-Z: http://aezay.dk/aezay/ssdz/
GPU-Z: https://www.techpowerup.com/gpuz/
CPU-Z: https://www.cpuid.com/softwares/cpu-z.html
Z-Info 1.0.45.32 Repack by Elchupacabra
Quote
Edited by 大†Shinegumi†大
