Universal Share Downloader v1.3.4.8
Dimonius Homepage Mirror1 Mirror2
PROGRAM
USDownloader-pure (Program of All plugins + + languages), SSL
Update-Servers =>
Before you ask a question, read
FAQ and FAQ for Cap
and make sure you have the latest versions of plug-ins.
READY ASSEMBLIES AND OTHER BASIC TOOLS
Setup by KireevSasha (18.11.2007)
USDownloader 1.3.4.8 + Rapidshare.com, FileFactory.com, Ifolder.ru, Letitbit.com and others popular. Thanks to Kis_s for Cap. (to update run CapUpdateRS.bat)
Build by blackmanos (20.11.2007) Mirror Website
Put in the USD folder and start, into assembly enters cap from kis_s, anticaptcha from saltlake and fbt for Finereader 8.0. Works with Rapidshare.com, FileFactory.com, MegaUpload.com, DataCod, IFolder, Uploading.com, etc. automatic updating the fonts, the assembly and updating of plug-ins Is built in. If you get the error message " Can't find script engine VBScript " because the dynamic link library (DLL) VBScript. DLL is not properly installed on your computer. Is is likely this file (VBScript. DLL) is missing, so all you have to do is type " regsvr32 VBScript " in a Command Prompt or in the Run Dialog (Start-> Run)
Cap v1.7.8.10 by Kis_s (18.11.2007) Website
Rapidshare, FileFactory, MegaUpload, iFolder, DataCod. Program of rapid recognition (instead of FineReader) + built-in Cheker + of the Setup. Its placed in the the native USD folder. The integration of automaton is described on website
Setup by SeVeS (20.11.2007)
In assemblies are AntiCaptcha v3.6.8 vy saltlake and USD v1.3.4.8.
