September 23, 200619 yr Here's a real simple, quick and easy interface button you can make with PhotoFiltre. In order to complete this tutorial you will need the Gravure Filter and the RGB Fantasy Filter. You can download them both for free on the PhotoFiltre Web Site. Just click on the Plug-ins Link to the left. Once you have them installed you can access them from the Filter / Plug-in menu or your plug-in tool bar if you have them set up there. RGB Fantasy is a Plug-in I use quite often so you may want to download it even if this tutorial is of no interest to you. 1) Open up a new image 200 x 200 with a black background. 2) Select the Rectangle Tool a draw a 150 pixel wide x 40 pixel high rectangle. Note: you may want to place it up to the top like mine if you plan on making more than one button. 3) Menu = Filter / Color / Gradient Style = Duotone Direction = Top to Bottom Color 1 = RGB 255,255,255 Opacity = 100% Color 2 = RGB 150,150,150 Opacity = 100% 4) Menu = Filter / Stylize / Progressive Contour Width = 3 Color = RGB 0,0,0 Opacity = 100% Effect = None 5) Menu = Selection / Contract Width = 10 6) Menu = Filter / Stylize / Progressive Contour Width = 3 Color = RGB 0,0,0 Opacity = 100% Effect = Blur 7) Menu = Selection / Expand Width = 10 8) Menu = Filter / Plug-in / Gravure Select the Contours+ Tab Setting = Diaphagme +1 9) Menu = Selection / Contract Width = 10 10) Menu = Filter / Visual effect / Gaussian Blur Radius = 1 Pixel 11) Menu = Filter / Plug-in / RVB Fantasies Select the RVB+ Tab and start playing around with the different color Combinations until you find something you like. Thanks to This Site
