Posted November 25, 200717 yr WildBit Viewer is compact & fast image viewer with slide show and editor. Eye catching interface within blazing fast folder, file list and thumbnail viewer. Viewer includes also Image Info with Image EXIF meta data JPEG and TIFF support and IPTC (IIMV4) information (like PhotoShop file info) from JPEG and TIFF, Thumbview has changeable views, sorting and thumbnail predefined sizes for fast thumbnail size setting.WildBit Viewer also includes shell toolbar, you can drop your favorite folder there and use it as an organizer. It also includes image compare. In Compare you can compare images side-by-side. In Favorites you can save list of favorite images and load list later on and you can create custom show in to Slide Show also that list you can edit with Custom Show List Editor. With Slide Show you can view images within 172 different transition effects. Slide Show includes now multi-monitor support for fast switching between two monitors. WildBit Viewer supports all major graphic formats including BMP, JPEG, JPEG 2000, GIF, PNG, PCX, TIFF, WMF and TGA (about 70 formats).WildBit Viewer is provided as freeware for private (non-commercial) or educational (including non-profit organization) use. In these cases, you are granted the right to use and to make an unlimited number of copies of WildBit Viewer. Viewer:- Explorer style file handling with customizable headers- Full screen View- Favorites- Thumbnail Browser with sorting, view change and fast thumbnail size change- Shell Tool Bar for organizing images- Image Rotate- Wallpaper set capability- Image Compare with calculating similitude of two selected images- Image Info with Image EXIF meta data JPEG and TIFF support, IPTC (IIMV4) information (like PhotoShop file info) from JPEG and TIFF and XMP Info support from JPEG, TIFF, PSD.- Rename Selected a.k.a Mass Renaming- File List Generator which generates html, csv, rtf, uni and txt files- Zoom & Pan- Expanded View- Image Geo Info and Show in Google maps- Animated GIF -support- Multipage TIFF -support- Camera RAW -supportSlide Show :- 172 transition effects- Image Marking- Normal or Custom Show- Custom Show List Editor- Desktop Mode with Tiled,Centered,Stretched,Smart or Custom Position (JPEG only)- "multi-monitor" support for fast switching between two monitors- Full screen View- Image Rotate- Image Change by Turn, Random or ShuffleEditor :- Printing- Acquiring images from scanner- Multiple-undo/redo levels- Cut,Copy,Paste- Crop- Histogram- Image Auto Adjustments (Auto Luminosity, Auto Sharpness, Auto Equalize, Auto White Balance, Auto White Balance (Gray World) and Auto Image Enhance)- Image Color Adjustments (Contrast, Brightness, HSV, HSL, RGB, Equalization, FFT, Gamma Correction and Sharpen)- Converting to Gray Scale, Negative, BW or True Color- Get HSV and RGB Channels- Edge Detection- Image Rotate and Flip- Image Resize and Canvas Resize- Selection with (Rectangle,Polygon,Circle,Lasso or Magic Wand)- Effects (User made filters,Bump map,Lens,Wave,Morphing filters,Rotate)- Merge selected images- Red Eye Removal- Soft Shadows- Lossless Transform- Custom Area selection- Zoom and pan- Navigator- Image Capture from Desktop, Area, Window etc- Batch with actions and converting to another format (bmp, jpg, png, tif, pcx, tga and ico) is possible- Metadata Clearing (Exif, IPTC or Both)- Camera RAW -supportPlus :- Supports all major graphic formats including BMP, JPEG, JPEG 2000, GIF, PNG, PCX, TIFF, WMF and TGA (about 70 formats).Homepage & Download Edited November 25, 200717 yr by cro-man
