VideoInspector is a tool designed to provide you with as much information as possible about your video files. With VideoInspector you'll know why your video files has no sound or refuses to play correctly. VideoInspector will help you installing the required CoDecs (coder/decoder software) for an optimal performance. VideoInspector can also inspect your system to find which codecs are available, and it can also process multiple video files and export its result in HTML or plain text files.
VideoInspector features ...
Container support : AVI, Matroska, MPEG I, MPEG II, QuickTime
Codecs requirements automatic detection
Lists installed Audio & Video Codecs
FourCC Changer
Bitrate Grapher
Batch file analysis, exports to CSV and HTML files
File intergrity check
Download required codecs (Online Database)
Automatic, content based container format detection
Displays movie info : Duration, streams
Displays Video stream info : Resolution, bitrate, frames per seconds (FPS)
Displays Audio stream info : Sample rate, bitrate, number of channels
Calculates video quality factor
Ability to burn CDs/DVDs (requires CopyToDVD)
Windows Shell Integration (Drag'n'Drop and Context menu)
International support
And much more !
Translations (included in installation package)
English
French
Catalan
Traditionnal Chinese
German
Italian
Polish
Ukranian
Croatian
Indonesian
Danish
Dutch
Hungarian
Slovak
Serbian
Spanish
Norwegian
Greek
Czech
Galician
Latvian
Estonian
Russian
Simplified Chinese
Portuguese
Romanian
Finnish
Korean
Hebrew
Belarussian
Slovenian
Albanian
Codec Packs containing VideoInspector
MUSK Codec Pack
VD Codec Pack
X Codec Pack
Edited by cro-man
