Vishal Gupta Posted November 29, 2007 Share Posted November 29, 2007 Hi guysCan you pls disable "Create a stronghold auto-log in cookie?" option in ACP? ACP -> Tools & Settings -> CookiesIt creates problems. If you get disconnected, the forum forgets you even you had selected "Remember Me" checkbox and you have to login again. Quote Link to comment Share on other sites More sharing options...
Tarun Posted November 29, 2007 Share Posted November 29, 2007 (edited) Never had any issues with it here. Since IPB fixed it, this feature has worked great. Edited November 29, 2007 by Tarun Quote Link to comment Share on other sites More sharing options...
Vishal Gupta Posted November 29, 2007 Author Share Posted November 29, 2007 I'm on dial up connection and if I got disconnected accidentally, the forum logs me out and I have to re-login.Its a known issue in IPB which occurs due to the option I mentioned. Quote Link to comment Share on other sites More sharing options...
NIM Posted November 29, 2007 Share Posted November 29, 2007 Although it's less secure to have this option disabled, I've did it for you..If you get better connection in time, please let me know Quote Link to comment Share on other sites More sharing options...
Vishal Gupta Posted November 29, 2007 Author Share Posted November 29, 2007 Thanks buddy. Much appreciated. Quote Link to comment Share on other sites More sharing options...
ricktendo Posted November 29, 2007 Share Posted November 29, 2007 Yea when my net goes down and I use my dialup backup I have to log in each time I visit wincert because my IP has changed. Quote Link to comment Share on other sites More sharing options...
NIM Posted November 29, 2007 Share Posted November 29, 2007 Yea when my net goes down and I use my dialup backup I have to log in each time I visit wincert because my IP has changed.But don't you guys have username and password saved, so you just need to click OK to login?Anyway, that's two of you now which will find this option disabled very useful.. Quote Link to comment Share on other sites More sharing options...
Vishal Gupta Posted November 29, 2007 Author Share Posted November 29, 2007 (edited) @RickExactly. And I never faced this problem in any forum using IPB except this forum and Joejoe (I have disabled this option long time back there), so that means most of the IPB forums keep this option disabled bcoz there are many members using dial-up connections. @N1kThis option records the IP address too and when a user using dial-up gets disconnected, his IP address is also changed bcoz dial-up ISP don't provide static IP addresses. Edited November 29, 2007 by Vishal Gupta Quote Link to comment Share on other sites More sharing options...
