Posted December 3, 200717 yr Revo Uninstaller helps you to remove any unwanted application installed on your computer.With its advanced and fast algorithm, Revo Uninstaller analyzes an application's data before uninstall and scans after you uninstall an application. After the program's regular uninstaller runs, you can remove additional unnecessary files, folders and registry keys that are usually left over on your computer. Even if you have a broken installation, Revo Uninstaller scans for an application's data on your hard disk drives and in the Windows registry and shows all found files, folders and registry items so you can delete them.With its unique "Hunter mode", Revo Uninstaller offers you some simple, easy to use, but effective and powerful approaches to manage (uninstall, stop, delete, disable from auto starting) and to get information about your installed and/or running applications.Revo Uninstaller gives you another 8 handy and powerful tools to clean up your system.Here are the list of all of the tools and utilities that are included:Auto Start Manager - stop programs that start automatically when Windows starts; Speed up loading of Windows!Windows Tools Manager - handy and useful tools bundled with every version of Windows; Easily find useful system tools and options!Junk Files Cleaner - find and remove unnecessary files from your computer; Free up disk space and delete data you do not need!Browsers History Cleaner - erase the web site history, visited pages history and temporary internet files of Firefox, Internet Explorer, Netscape and Opera web browsers; Free up a lot of disk space by deleting temporary internet files like temporary saved videos, flash files, pictures etc!Office History Cleaner - remove the history of most recently used files in MS Office; Remove your tracks by deleting the list of last opened MS Office documents!Windows history cleaner - remove the history of recently opened files, delete temporary files, remove usage tracks and other history items that are saved by Windows; Remove your tracks saved by windows for a lot of operations!Unrecoverable Delete Tool - erase files and folders forever; Be sure that nobody could recover your files and folders after deleting!Evidence remover - make sure already deleted files, folders and other data are unrecoverable; Revo Uninstaller is completely free - no cost, no adware, no spyware. Portable
