DEViANCE Posted December 9, 2007 Posted December 9, 2007 (edited) ESET NOD32 Edited December 9, 2007 by DEViANCE Quote
shahed Posted December 9, 2007 Posted December 9, 2007 hican you please make eset smart security addon please?thanks in advance Quote
Mr_Smartepants Posted December 9, 2007 Posted December 9, 2007 hican you please make eset smart security addon please?thanks in advanceEasy enough to make. First, download the trial version from ESET.The comment you use is:start /wait msiexec.exe /i ess_nt32_enu.msi /qb /norestart Quote
shahed Posted December 10, 2007 Posted December 10, 2007 hithanks so much for the security :thumbsup_anim: Quote
DEViANCE Posted December 10, 2007 Author Posted December 10, 2007 No problem, personally i don't like it, it alerts me to way to much stuff and half most of the time its just because im editing system files etc.. So i just use the anti-virus.Does anyone know the reg entries for the AV to input my username and password??I look into the registry and could only find the username field, no password field?? Quote
Mr_Smartepants Posted December 10, 2007 Posted December 10, 2007 Does anyone know the reg entries for the AV to input my username and password??You go to the 'Setup' tab, enable 'Advanced mode', then click 'Import/Export settings'. You'll end up with an .xml file (username/password are encrypted).Now if you can figure out how to apply those settings unattendedly during install...that's important!. Quote
bober Posted December 10, 2007 Posted December 10, 2007 well i think the question is, is there any way to feed the info or edit the .msi installer. Quote
shahed Posted December 10, 2007 Posted December 10, 2007 (edited) hey deviance,here you go with the registry username and password entry:HKEY_LOCAL_MACHINE\SOFTWARE\ESET\ESET Security\CurrentVersion\Plugins\01000400\Profiles\@My profile]"UpdateType"=dword:00000002"Username"="xxxxxxxxxxxxxx""Password"=hex:xxxxxxxxxxxxxxxxx Edited December 10, 2007 by shahed Quote
shahed Posted December 14, 2007 Posted December 14, 2007 hi is there anyway to edit this addon, and create an fully updated NOD32 3.0 with the latest virus definitions like the nod32 2.7 created by Deviance? Quote
Helmi Posted December 23, 2007 Posted December 23, 2007 3.0.621 is out for both AV as well as ESS, any chance of an update? =) Quote
