ImDisk Virtual Disk Driver v1.0.3
ImDisk is a virtual disk driver for Windows NT/2000/XP/2003. It can use one or more disk image files to create virtual hard disk, floppy or CD/DVD drives .The install package installs a console-mode control program called imdisk.exe and a Control Panel applet. After install is finished, type imdisk without parameters for syntax help or double click the ImDisk icon in the Control Panel. It also adds a menu item in Windows Explorer so that you can right-click on a file to mount it as a virtual disk drive. Users of mdconfig in FreeBSD will probably be familiar with the command line syntax of imdisk.exe. The driver, service and control program can be uninstalled using the Add/Remove programs applet in the Control Panel. No reboot is required for installing or uninstalling.
Download link
http://rapidshare.com/files/75725932/efg_I...v1.0.3.cab.html
MD5: 730DC92F169820B31D67BA64868C41AF
