December 11, 200717 yr Cool. Thanks for the linky lol I tried 4 different PC configs, and I got the same 3 PSUs each time Oh well, I may get a new PSU if I decide to upgrade my video card. But at this point in time, I don't think I'll be changing cards. Edited December 11, 200717 yr by cygnus
December 11, 200717 yr Author Even if you're overclocking you don't need anything stronger than 520w of "true power".If you use SLI or Crossfire then you have a totally different story, for that you'll need more power..
January 9, 200916 yr Even if you're overclocking you don't need anything stronger than 520w of "true power".If you use SLI or Crossfire then you have a totally different story, for that you'll need more power..How the things changing over years...My VGA needs 580W real power minimum GF 9600 512MB 256bit DDR3
January 10, 200916 yr How the things changing over years...My VGA needs 580W real power minimum GF 9600 512MB 256bit DDR3Actually DennyMK I would agree with N1K, there is much more things and explanations that I'm capable of writing at the moment. But in the meantime you might check this article....for the start.
January 10, 200916 yr Author How the things changing over years...My VGA needs 580W real power minimum GF 9600 512MB 256bit DDR3No way that this card needs so much power. If I'm correct my 8800GT is stronger card than yours 9600 and I don't need anything near that power you specified..
January 10, 200916 yr I have a 9500gt on a 500psu with 2 dvd burners, 4 sata hard drives and it has been WAY overclocked. NO power issues yet...
January 10, 200916 yr Actually DennyMK I would agree with N1K, there is much more things and explanations that I'm capable of writing at the moment. But in the meantime you might check this article....for the start.Read about exceptionsNo way that this card needs so much power. If I'm correct my 8800GT is stronger card than yours 9600 and I don't need anything near that power you specified..Than watch this: I have a 9500gt on a 500psu with 2 dvd burners, 4 sata hard drives and it has been WAY overclocked. NO power issues yet...Read my specs and 500W makes somethimes my system shut down cause of the PSU (when I play games, and neither one part of my PC is not over clocked)My Computer Specifications(Click to Show) PSU (No-Name): 500W (don't know if it's real power or not)MB:AsRock TurboTwins 2000CPU: Pentium D (925) 3GHz 2x2MB FSB 800 (95W)Ram: 2x2GB DDR2 800 Kingmax (dual channel)HDD1: Seagate ST3500320NS SATA2 500GB 32MBHDD2: Maxtor STM380811AS 80GB SATA2 8MB2xDVD RW SamsungVGA: Galaxy GeForce 9600 GT 512MB 256bit PCI-E 2.0 DDR3Monitor: Samsung Samsung SyncMaster 2032BW 20.1"plus camera, cable modem, speakers, a few case fans, CPU fan[Close]So if anyone knows how to calculate what power (PSU) do I need, please let me know.(I will replace my CPU to E8500 or Q9300 after a couple months) Edited January 10, 200916 yr by DennyMK
January 10, 200916 yr @DennyMK that minimum system requirements.it says 580W minimum so that power supply can power all of your system. i.e CPU, HDD's, MoBo.... etc..the graphics card must use about 50W-200W?
January 10, 200916 yr @DennyMK that minimum system requirements.it says 580W minimum so that power supply can power all of your system. i.e CPU, HDD's, MoBo.... etc..the graphics card must use about 50W-200W?I know that, and I was talking about whole system. Off-Topic Comment(Click to Show) Anyway getting power cut-offs when I play Far Cry 2 (when more than 2 people start shooting at me :thumbsup_anim: and sometimes =shut down )[Close]
January 10, 200916 yr I know that, and I was talking about whole system. Off-Topic Comment(Click to Show) Anyway getting power cut-offs when I play Far Cry 2 (when more than 2 people start shooting at me :thumbsup_anim: and sometimes =shut down )[Close]look at N1K Post!
January 10, 200916 yr Author PSU (No-Name): 500W (don't know if it's real power or not)This is the answer to your dilemma. Your NO-NAME PSU probably doesn't have "real" 500W, but maybe roughly 250-300W. I'm positive that your restarting problems are related to PSU.Try to replace your PSU with some better one, for instance from Corsair, Thermaltake or similar manufacturers.PSU is among the most important parts of your PC to have a stable system.
January 10, 200916 yr Agreed with N1K and would also like to say that Antec, Enermax, OCZ, Silverstone or Zalman are also great PSU manufacturers.
January 10, 200916 yr This is the answer to your dilemma. Your NO-NAME PSU probably doesn't have "real" 500W, but maybe roughly 250-300W. I'm positive that your restarting problems are related to PSU.Try to replace your PSU with some better one, for instance from Corsair, Thermaltake or similar manufacturers.PSU is among the most important parts of your PC to have a stable system.Yeah, I like Thermaltake. Looks great to me. But unfortenatelly, can't buy it now. And it will be >=600W. Thanks for your help
January 10, 200916 yr Author Yeah, I like Thermaltake. Looks great to me. But unfortenatelly, can't buy it now. And it will be >=600W. Thanks for your help I would definitely recommend you Corsair V550W which I'm using and it is very stable and strong PSU. Even better would be Corsair H620W which is stronger and also a modular version. Honestly, if I'm buying a new PC now, I would surely choose H620W. :icon_cool:
January 10, 200916 yr I would definitely recommend you Corsair V550W which I'm using and it is very stable and strong PSU. Even better would be Corsair H620W which is stronger and also a modular version. Honestly, if I'm buying a new PC now, I would surely choose H620W. :icon_cool:Yep, I agree about stronger is better :thumbsup_anim: Thanks for advice Edited January 22, 200916 yr by DennyMK
January 21, 200916 yr So the time to get a new PSU has come. I need a little help to decide about two PSU's and need your advice which one to buy.The best I could find here in Macedonia and with real-power are these two:Gembird 650W real power (52euros)andGlacialTech 650W real power (73euros).
January 22, 200916 yr Never heard of those two. I still stand for Corsair.I don't have a better choice. Those two are the best in whole MK. So, please look at the specs from those 2 links and tell me what to buy. :help: Edited January 22, 200916 yr by DennyMK
January 22, 200916 yr GlacialTech!Thanks. I was about to buy that one but I wasn't sure. Your answer helped me to make a decidion
October 19, 201113 yr someone came out with a new/ better? psu calculator http://hardforum.com/showthread.php?t=1643188
