i have a couple of pc with xp pro would like to install vista on one of them to see if i like vista but i want to do a clean install so if i take off xp for 4 to 6 mo will i be able to reactivate my copy of xp pro or will i be stuck with vista
thanks
thanks
It depends on how many times you have activated it, I think there is a limit of around 20, you will get a message stating that the registration has bee acceded when you reach the limit, then all you have to do is call MS and notify them why you have acceded the limit, they will then reset your account.
