大†Shinegumi†大 Posted November 6, 2022 Posted November 6, 2022 (edited) Sorts your image at high speed. The central philosophy behind Image Sort's design is speed. For that reason the ideal way to use this app is not to leave the keyboard. However, you can of course use the app in any way you wish and ideally it should still help you sort your images fast. Requires Windows 7 SP1 or higher Prerequisites: .NET 7 SDK (optional) Visual Studio 2022 Version 17.5 or higher (optional) For building the installer, you need WiX Toolset 3.11 or higher === Silent installation Quote https://www.mediafire.com/file/a9l4hkzugioiuvy/Image+Sort+2.14.0+AIO+Silent+Install.rar/file https://mir.cr/16NSPD83 Edited October 9, 2024 by 大†Shinegumi†大 Quote
大†Shinegumi†大 Posted October 9, 2024 Author Posted October 9, 2024 Update https://github.com/Lolle2000la/Image-Sort/compare/v2.13.0...v2.14.0 Quote
