Posted December 15, 200717 yr PStart is a simple tray tool to start user defined applications. Designed to run portable applications (like portable Firefox & Thunderbird), you can start anything runnable from USB key devices or removable disks. * Install PStart locally to your hard disk to have an additional start menu with a quick program search feature. * Install PStart to your USB stick to launch portable applications easily and open important documents or folders.Take a look at PStart screenshots and 3rd party portable applications.
December 15, 200717 yr Off Topic: Hey croatia man do you know of any good auto shutdown programs to shutdown my PC? (freeware of shareware).I ask you because you got allot of good recommendations (a.k.a. cro-ware )
