Posted December 15, 200717 yr Transbar is a little tweaking tool which takes advantage of Alpha Transparency in Windows 2000 and Windows XP. Using TransBar, you can adjust the transparency level of your taskbar meaning that a full screen wallpaper is made partially visible through the taskbar. * Version: 1.4.2 * License: Freeware * Requirements: Windows 2000/XP/2003/Vista screenshothttp://www.home.no/aksoftware/products/transbar/ss1.jpgdownloadhttp://www.home.no/aksoftware/products/tra...Bar%20setup.exe Edited December 15, 200717 yr by dude-uk
