Description from developer:
Google Hacks is a compilation of carefully crafted Google searches that expose novel functionality from Google's search and map services. For example, you can use it to view a timeline of your search results, view a map, search for music, search for books, and perform many other specific kinds of searches. You can also use this program to use google as a proxy.
The name should not imply the way it should be used.
Hacks is meant as this definition. "A Hack is a modification of a program or device to give the user access to features otherwise were unavailable to them. " Taken from Wikipedia.
Please do not use this program for illegal uses.
What im hoping by releasing this program is that it will help crack down on illegal and illegally distributed copyrighted material.
