January 28, 200817 yr Author havent tried it yet. if the kernels havent been updated, it should be fine. if they have been changed, it wont work.
January 29, 200817 yr no it dont work properly with build 3282 rcr2when installing all is ok.. after first re-boot when installing.. is ok and it shows upafter second re-boot when installing.. it dont show up at all now..after third re-boot when fully installed.. it dont show up at all now..so does the kernels do need updating i reckon..can you please remake vista boot screen so it works ok with sp3 build 3282many thanks in advance Edited January 29, 200817 yr by dude-uk
January 29, 200817 yr Author no it dont work properly with build 3282 rcr2when installing all is ok.. after first re-boot when installing.. is ok and it shows upafter second re-boot when installing.. it dont show up at all now..after third re-boot when fully installed.. it dont show up at all now..so does the kernels do need updating i reckon..can you please remake vista boot screen so it works ok with sp3 build 3282many thanks in advanceyeah, i'll try and have one up in a day or so....did the taskman work?
January 30, 200817 yr Author any chance of getting the german files for thatRubenupload the kernels somewhere, i'll see what i can do
February 10, 200817 yr link to build 3300 coming up with error while getting dl ticket any pointers thanks
February 10, 200817 yr link to build 3300 coming up with error while getting dl ticket any pointers thanksworks fine here fella..
February 10, 200817 yr @ hngovr1 Thanks a lot buddy !!! :thumbsup_anim: It works like a charm with sp3 rc2 build 3300 :icon_cool: ps. I hope You got my last PM
February 11, 200817 yr any german version?? There are some torrent downloads but here in peru thats a not ending storyRuben
February 11, 200817 yr here are the german 3300http://rapidshare.com/files/91034352/ntosk...2600.300_deu.7zRuben
February 19, 200817 yr Author i dont have the 3244 kernels, but if you send them to me, i'll fix you up....
February 24, 200817 yr Perhaps something went screwy with the links during the recent forum Hosting Server crash. Though someone may know better.Anyway here is a link which may be of use in the mean time. Edited February 24, 200817 yr by silversurfer
February 24, 200817 yr Perhaps something went screwy with the links during the recent forum Hosting Server crash. Though someone may know better.Anyway here is a link which may be of use in the mean time.I've removed the BBCode for downloads since it was messed up, but it shouldn't removed the links.. :confused02:I've also edited your fist post and put the download links in it.
February 26, 200817 yr Author just fixed all the links. first one disappeared, and third was wrong. but all work now.nik, do i need to fix the code on my others?
February 26, 200817 yr Author Is there an addon for build 3311? yup, i'm working on it, it'll be out in a few days
March 13, 200816 yr Author i'm not actually making a 3311 bootscreen, somebody at MSFN already made one...
March 19, 200816 yr i'm not actually making a 3311 bootscreen, somebody at MSFN already made one...hi hngovr1.. check your mail.. can you check out the 'sp3 5503 vista bootscreen addon' ive done and if its ok add to top post with others
March 19, 200816 yr hi hngovr1.. check your mail.. can you check out the 'sp3 5503 vista bootscreen addon' ive done and if its ok add to top post with othersI'll test it out...hngovr1 sent that to me...stay tuned Edited March 19, 200816 yr by dareckibmw
