Posted December 28, 200717 yr alright guys, today I've bought an external numpad to my laptop....The deal is, I work a lot in hexadecimal, is there anyway I could repoint the "-" key to "A", and so on, with the rest of the keys ? Also, is there anyway to point 'F1' to make a folder when I push it ?
December 28, 200717 yr See if any of this apps will fit your needs..http://www.download32.com/keyboard-replacement-software.html
December 28, 200717 yr Thanks, N1k, but I was looking for something 'newer' Problem is that I haven't used such an app, I'll try to search something newer..
December 28, 200717 yr Author Well alright, anyways thanks for trying, I will be very happy if you find something, it doesn't have to be freeware
December 28, 200717 yr Well alright, anyways thanks for trying, I will be very happy if you find something, it doesn't have to be freeware We can always wait for Cro-man to show up. He's a software finder king.. :icon_cool:
December 29, 200717 yr Yeah, that guy is a true guru at that point Introduction to MapKeyboardMapKeyboard is a free program to remap your keyboard. Using MapKeyboard, you can alter any key on your keyboard to function as a different one or altogether disable it as well. This is an essential tool for laptop users and other people with keyboards whose keys differ from the standard 101 keyboard layout. The changes made are universal across all applications & games and best of all, MapKeyboard does not even need to be actively loaded in memory.Note: MapKeyboard is not a hotkey program, if you need to assign actions to single or multiple keys, consider using Hotkeycontrol.Key features * Officially supports Windows Vista * Changes are made at a low level so that they take effect in all programs and 3D games * This remapper does not need to be loaded in memory all the time * Supports disabling of keys rather than remapping them 30 kb
December 29, 200717 yr Author I knew that master cro-man would find something, man do I love your skills! You're awesome man!
May 25, 200816 yr Author Well.. Since this is about keys, I won't make a new topic.SOMETIMES when I'm on my laptop, and posting/writing stuff, it somehow "holds the ctrl button"!I mean, example: I had just finished making a post on a forum, made the "=)" smiley, and posted.After it posted, I couldn't write anything (well, if i hit "S" in firefox (even if the focus was on the adress bar) it would open the "save as.." dialog), it just said a lot of error sounds (system sounds, when you do something wrong etc.), and when i tried to write numbers, it wrote the symbols.. I mean it wrote "$" when I was hitting "4" (DK layout keyboard, for writing "$" I must hold down "ALT-GR+4", this is pretty weird, as before it seemed like it hold my CTRL button.This is getting pretty annoying as it happens in some critical times when I really need to use the keyboard. (Once I was writing a .doc, and then it hold some button and it made "Select all+delete", and I couldn't redo since it just made a system sound when I pressed "CTRL+Z".)Thanks in advance! Mr. Thunderbird. =)
May 27, 200816 yr Well just remove the button LOL Naw just kidding, can you carefully pop it off and clean it and below it?
May 27, 200816 yr Author Well, the problem seems to have disappeared after I disabled some LOCKS in the 'handi' menu on Vista, I doubt it was that tho'. And I doubt that it was dirty, because its brand new laptop.
October 13, 200816 yr I know another utility that can do the same but looks a bit better Qliner hotkeys 2.01Qliner hotkeys is a free and open source keyboard productivity environment. It is the first product of its kind that is usable by computer geeks and non geeks alike.Hotkeys builds on the concept of Windows shortcut keys but takes this concept to a whole new level. Do you think key combinations are hard to remember? Just hold the Windows key for three seconds and up pops a on screen Keyboard with icons on the keys that are configured. This you can use , not only to remind you of hotkey combinations, but also for Drag and Drop Configuration.Smart application launching and switchingHotkeys is smart in the way it launches applications and opens documents. When a key combination is pressed hotkeys will first try to find an existing instance of the requested application or document and bring that to the front. This behaviour can be overruled by holding the Alt key, which ensures that a new instance is allways launched. If no existing instances are found a new instance is started. If multiple instances are running the Instance Switching menu is displayed.Drag and drop configurationHolding the Windows key for several seconds, or pressing Win + Z shows the on screen keyboard. It is an easy tool to look up existing key combinations. The keyboard is also used for drag and drop configuration: you can drag the icons on the keyboard to different keys or drag new items onto the keyboard.The keyboard is highly configurable. You can change the color and layout to make it match your actual, physical keyboard. Besides support for more than 100 international keyboards layouts, hotkeys also supports Dvorak layout.cheers
