WinXP Manager is a system utility that helps you optimize, tweak, and clean up Windows XP. It will increase your system speed, improve system security, and meet all of your expectations.
It's compatible with Windows XP SP2 entirely!
You also can change your Logon Background Picture that it looks like in Vista and/or you can change your OEM (Original Equipment Manufector) images into you own.
But there are much more possibilities and I'm using it for 2 years already and highly recommend this to everyone who likes to tweak his OS :thumbsup_anim:
For everybody who want the StartUp Image Startup.jpg like it is in Vista HERE you can download the bmp file
The rar.file contains to images...one is for wide screen like most Laptops have and the other is for normal screen resolution
Edited by JurgenDoe
