pip22 Posted January 3, 2008 Posted January 3, 2008 I've recently re-installed the Sidebar on my Windows XP owing to a failed disk, and the Slide Show gadget doesn't give me any options. The options box opens but all the fields are blank so I can't select a folder, a transition-effect or a time-duration. Any ideas on why this is so?TIAPip Quote
LUZR4LIFE Posted January 3, 2008 Posted January 3, 2008 If your having issue with any gadgets, there is a little tutorial HERE. Quote
ricktendo Posted January 3, 2008 Posted January 3, 2008 Here, try deleting the one in the gadgets folder and replace it with this http://www.mediafire.com/?0wu2jnekxez Quote
