Posted April 18, 20231 yr Tab management leveled up, more efficient browsing and squashed bugs: Vivaldi 6.9 is here! Vivaldi 6.9 brings powerful new features like tab renaming for better organization, drag-and-drop downloads for quicker file management, and a clearer view of your synced tabs across devices. We’ve also fine-tuned Vivaldi Mail and squashed some bugs to keep things running smoothly. Read this article in español, 日本語, русский, français, Deutsch, język polski. Today, we’re excited to introduce Vivaldi 6.9 — a release that may seem subtle at first glance, but is full of improvements. We’re committed to making every release meaningful, whether it’s packed with new features or focused on fine-tuning the experience you already love. This update is all about refining what makes Vivaldi special: giving you powerful tools to personalize your browser, stay organized, and navigate the web your way. While Vivaldi 6.9 includes important bug fixes and performance improvements, we’ve also added a few new features that we think you’ll really appreciate. Rename your tabs Get organized with custom tab names. With Vivaldi 6.9, we have added a standout feature designed to help you stay organized. You can easily rename your tabs and Tab Stacks to something that makes sense to you. Whether it’s a project name, a reminder, or anything else that helps you stay organized. This feature is particularly useful when you’re working on multiple projects at once, conducting research, or juggling various tasks throughout the day. It helps you keep your tabs neat and organized, making it easier to find what you need when you need it. Drag Files Directly from the Downloads Panel File your files with ease, directly from the Downloads Panel. We’re all about efficiency, and our new drag-and-drop functionality from the Downloads Panel is sure to make you more efficient. In Vivaldi 6.9, you can drag files directly from the Downloads Panel to your desktop, a folder, or even into an email or document. No more digging through your download folder, just grab what you need and drop it where it needs to go. You can mark multiple files in the Downloads Panel to be moved simultaneously. This feature lets you streamline your workflow, making management of downloaded files easier and quicker. Whether you’re downloading images, documents, or software, this small but powerful enhancement will save you time and keep you focused on your task at hand. View Synced Tabs in a Clear Structure Get a structured view of tabs you have synced across your desktop devices. If you use Vivaldi across multiple desktop devices, you’ll love this feature. With Vivaldi 6.9, you get a new structured overview of all your open tabs directly in the Windows Panel. When you open the Windows Panel you can see exactly which tabs are open on your other desktop devices, neatly organized in a tree structure. The new structure separates the devices, Workspaces and Tab Stacks. This makes it easier than ever to pick up where you left off when you’re moving from your desktop to your laptop. Mail Improvements for a Smoother Experience Back in June, we launched Vivaldi Mail 2.0 and we’ve made several improvements to Vivaldi Mail in this release. If you check the changelog you can see we have made more than 40 fixes for Mail and Calendar. We’ve focused on enhancing stability and performance, ensuring that your email experience is as smooth and reliable as possible. Whether you use Vivaldi Mail for work, personal communication, or managing multiple accounts, these updates will make your daily email routine more efficient and enjoyable. Bug Fixes and Performance Enhancements Of course, no release would be complete without a round of bug fixes and performance tweaks. In Vivaldi 6.9, we’ve addressed several issues reported by our community, improving everything from tab behaviour to user interface responsiveness. These fixes are all part of our ongoing commitment to making Vivaldi not just a powerful browser, but also a reliable one. You’ll find the full changelog at the bottom of this blog post. Ready to upgrade? Update to Vivaldi 6.9 today and discover these improvements for yourself. As always, we’re eager to hear your feedback, your insights help us continue to shape Vivaldi into the browser you need it to be. By the way – today marks the official debut of Vivaldi for Windows on Arm! Thank you for being part of the Vivaldi community. Together, we’re fighting for a better web one release at a time. Changelog from 6.8 to 6.9 [New][Windows] Promote ARM64 packages to official status [New][Sync][Tabs] Add tab structure (VB-108713) [New][Tabs] Allow tab renaming (VB-23686) [New][Downloads] Drag files from Downloads Panel (VB-13976) [New][Address bar][Settings] Add support for showing donator badge in UI (VB-108386) [New][Settings] Autofill for saved credit cards and saved addresses (Privacy settings) (VB-100960) [New][Blocker] Add support for uBlock ‘important’, ‘all’ and ‘redirect-rule’ rules (VB-108228) [New][Blocker] Add uBlock option aliases support (VB-107194) [New][Mail] Offer to quickly change ‘Reply’ to ‘Reply All’ (VB-108107) [New][Mail] Show fetching progress with pause and resume button in Mail Panel (VB-107070) [New][Mail][Keyboard] Send Quick Reply when pressing Ctrl+Enter (VB-106511) [New][Panels] Add a button that can toggle desktop/mobile mode for web panels (VB-107903) [New][Speed Dial] Multiple default groups for new users (VB-108732) [New][Workspaces] Add a command to move an active tab to a different Workspace (VB-107794) Address Bar [Address bar] Domain result unexpectedly centered in drop-down (VB-107857) [Address bar] Add some text padding (VB-107212) [Address bar] Badge hidden when small dropdown (VB-108036) [Address bar] Dropdown suggestion icon is grayed out (VB-108143) [Address bar] Should reset address field state when switching tab via dropdown (VB-107342) [Address bar] Some dropdown items are not selectable (VB-107878) [Address bar] Typing websites does not always offer going to root domain (VB-107020) [Address bar] URLs with line breaks are incorrectly parsed (VB-91961) [Address bar][Search] Hide Search Field by Default (VB-107846) [Address bar][Tabs][Workspaces] URL switch tabs doesn’t switch workspace (VB-108548) Bookmarks [Bookmarks] New bookmark folder disappears before I can give it a name (VB-104755) [Bookmarks] Sorting bookmarks bar by most recently created bookmark just sorts by alphabetical (VB-107770) [Bookmarks] “Added Bookmark” appears after restart (VB-108930) Calendar [Calendar] A single broken event stops syncing of whole calendar (VB-107396) [Calendar] Add possibility to set recurrence for last day/weekday of month (VB-101970) [Calendar] Can’t create/edit a full day event (VB-107863) [Calendar] Can’t delete “this and upcoming” tasks (VB-107731) [Calendar] Created calendars do not sync by default (VB-108020) [Calendar] Deleting calendars freezes confirmation popup (VB-108023) [Calendar] Event titles not properly escaped (VB-107427) [Calendar] Focus stolen from date picker dialog (VB-106507) [Calendar] Import to remote calendar creates a new local one (VB-107209) [Calendar] Keyboard navigation jumps to day (VB-108739) [Calendar] Navigating to vivaldi:calendar sets up first account but does not enable calendar feature (VB-107357) [Calendar] Single item failure in CalDAV parsing prevents valid items parsing (VB-107708) [Calendar] When deleting an event with participants, send a cancellation notice (VB-103989) Crash [Crash] During quit while thumbnail screenshot is taking place (VB-105451) [Crash] On closing tab by CTRL+W while using NVDA screenreader (VB-101331) [Crash] Relating to panel extensions (VB-105887) [Crash][Linux] Export password uses wrong parent window (VB-107881) [Crash][Linux][Settings] On exporting passwords (VB-108850) [Crash][Mac][Menus] Frequent Random Crashing (VB-108274) [Crash][Menus] A context menu can trigger a crash on exit (VB-108963) [Crash][macOS] On closing the “Leave site?” popup [beforeunload] (VB-104649) History [History] Diagrams doesn’t change colour after switching theme without reopen history page (VB-54623) [History] Items persists for a short while after clearing browsing data (VB-107530) [History][Performance] Various work to improve History Manager performance Windows 10/11 X64 X86 Silent installation Silent installation Quote https://www.mediafire.com/file/f8191ez0v1ql0x2/Vivaldi+6.9.3447.48+AIO+Silent+Install.rar/file https://mir.cr/GPAVU2A2 Windows Last windows 7 /8.1 تثبيت صامت Silent installation Vivaldi.5.6.2867.62 AIO Last windows 7 Install Silent Quote https://www.mediafire.com/file/a1o83u0fgk7f3k2/Vivaldi.5.6.2867.62+AIO+Last+windows+7+Install+Silent.7z/file https://mir.cr/IWV7BLFL https://workupload.com/file/txtFEutpAFZ Edited September 27, 2024Sep 27 by 大†Shinegumi†大
June 9, 20231 yr Author Changes in version 6.1 Build 3035.75 – Minor Update: Changes in version 6.1 Build 3035.51 – Final:
