LUZR4LIFE Posted January 10, 2008 Posted January 10, 2008 OK, My internet seems to be running real slow now and I have no ideal why.I did a speed test and my pings are at 39ms and my DL is at 5143 and my UL is at 256. What could be the cause of EVERYTHING loading slow???THANKS Quote
Kelsenellenelvian Posted January 10, 2008 Posted January 10, 2008 Hey same here my danm lappy is going soooooooooooooooo slow doing anything and it is a 2gig CPU with 1 gig ram. Quote
cygnus Posted January 10, 2008 Posted January 10, 2008 How many different sites have you checked? Cleaned temp folder?Also, if using Firefox, configure it to maximize connections.goto about:config in the address bar, then search for "network.http"These are the settings I use to test different things. Be careful obviously though, if you have too many connections it'll overload the server. I would recommend just changing the stuff to see if it may help, if not, I recommend putting 'em back. Quote
LUZR4LIFE Posted January 10, 2008 Author Posted January 10, 2008 (edited) How many different sites have you checked? Cleaned temp folder?Also, if using Firefox, configure it to maximize connections.goto about:config in the address bar, then search for "network.http"These are the settings I use to test different things. Be careful obviously though, if you have too many connections it'll overload the server. I would recommend just changing the stuff to see if it may help, if not, I recommend putting 'em back.Thanks. I forgot all about that. I found that on Vishal's site awhile back. I have tried a lot of sites. I also have no connections but will see if that helps. Edited January 10, 2008 by LUZR4LIFE Quote
