Mayapple Posted January 10, 2008 Posted January 10, 2008 (edited) I have my IE7 security set for protection mode enabled, however; when I open the browser it reports protection mode: off at the bottom of the brower window. When I double click there, it brings up the security tab which shows protection mode enabled. ??!!I've attempted to fix by going to Control Panel and re-setting Windows default programs, but that doesn't work.Can anybody suggest how to get the IE7 brower to report the correctly enabled protection mode?Thanks.Mayapple :confused02: mayapple@mayapple.net :thumbsup_anim: I found the fix! Had to go to my user account settings in Control Panel and put a check mark in "Use User Account Control (UAC) to help protect your computer".Confused No More! Edited January 10, 2008 by Mayapple Quote
NIM Posted January 10, 2008 Posted January 10, 2008 Glad you have figured it out. You were too fast Quote
