大†Shinegumi†大 Posted May 23, 2023 Posted May 23, 2023 (edited) Audacity is a free, easy-to-use and multilingual audio editor and recorder for Windows, Mac OS X, GNU/Linux and other operating systems. You can record sounds, play sounds, import and export WAV, AIFF, AAC, MP4, Ogg Vorbis, and MP3 files, and more. Use it to edit your sounds using Cut, Copy and Paste (with unlimited Undo), mix tracks together, apply effects to your recordings, change the speed or pitch of a recording, and really much more. Audacity enables FLAC support. The program also has a built-in amplitude-envelope editor, a customizable spectrogram mode, and a frequency-analysis window for audio-analysis applications. The program has the built-in effects, including Bass Boost, Wahwah, and Noise Removal, and it also supports VST plug-in effects. Audacity is without a doubt one of the best and easiest digital audio editors on the market and it will meet any requirement at 100% no matter if it is home or professional audio edition. Audacity Key Features: Cut, copy, splice or mix sounds together. Record live audio. Supports 16-bit, 24-bit and 32-bit (floating point) samples (the latter preserves samples in excess of full scale). Record computer playback on Windows Vista and later by choosing “Windows WASAPI” host in Device Toolbar then a “loopback” input. Import and Export WAV, AIFF, AU, FLAC and Ogg Vorbis files. Convert tapes and records into digital recordings or CDs. Edit WAV, AIFF, FLAC, MP2, MP3 or Ogg Vorbis sound files. Import and export AC3, M4A/M4R (AAC) and WMA with the optional FFmpeg library (this also supports import of audio from video files). Numerous effects including change speed or pitch and vocal reduction or isolation (given suitable stereo tracks). And more! See the complete list of features. ОС: Windows 11/10/8/7 Quote С: Windows 11/10/8/7 Silent installation https://www.mediafire.com/file/026ntfnnyq9nlpo/Audacity+3.4.2+AIO+Silent+Install.7z/file Edited November 18, 2023 by 大†Shinegumi†大 Quote
大†Shinegumi†大 Posted November 4, 2023 Author Posted November 4, 2023 Changes in version 3.4.0: Music workflows Audacity now features several music related features, such as switching between hh:mm:ss time and Beats & Measures, and time-stretching clips to align them to a song’s tempo. Time stretching Hold Alt (macOS: Option) while hovering over the top third of a clip edge to stretch it. New exporter Audacity now features a new export window with easier access to options such as sample rate and custom mapping (for 5.1 or 7.1 audio). Additionally, the “Browse” button uses the native file browser now! Other changes For MP3, Audacity now always uses Joint Stereo mode, which always delivers the best possible quality. Simplified pasting logic. Simplified stereo tracks. Left and right channels now always have synchronized clip starts and ends, and the same sample rate in both channels. Added cursors trimming and stretching left and right, and changed the I-beam cursor to be less similar to either. When importing audio, the project sample rate no longer changes. The spectrogram colors are now perceptually uniform, and the colormap has gotten a name: Roseus. It also can be used for dataviz outside of Audacity New defaults: The Time Signature toolbar now gets shown, the solo button is set to multi-track mode, time tracks have a wider starting range. Unsquished the Audacity logo found in some places of the app. Clicking on the border of two clips no longer merges them. Overdubbing on Windows fails with WASAPI with default Recording device. Built-in Opus support. Libraries lib-time-and-pitch implements a time stretching algorithm originating in Staffpad. Audacity now uses Conan 2. Continued extracting code into libraries and modules, especially in the context of importing and exporting. Bug fixes nogap metadata no longer is ignored. fixed a crash with LV2 plugins (thanks jfroyall!). fixed some crashes related to macros. fixed a crash when pasting in certain configurations. Accessibility: GUI can be disabled again for VST2 plugins (thanks, David Bailes!). Accessibility: Restored window control IDs, improving NVDA compatibility (thanks again, David Bailes!). fixed a crash on launch on OSX 10.9 (thanks, René Bertin!). Quote
