January 25, 200817 yr XdN Tweaker is small tool (516KB) and supports XP, Vista, and even Windows Server 2003. XdN can tweak things like disabling Windows Mail's splash screen, disabling user account control, better save folder views, remove or replace IE7's search box, disable the "send to" option, and much more.System Requirements:- Windows XP, 2003, or Vista- .NET Framework 2.0 if you are using Windows XP or Windows 2003.Windows Installer 3.1(.NET Framework 2.0 requires this, download only if you don
