ricktendo Posted January 31, 2008 Posted January 31, 2008 Media Center Plus AddOn for XP (a.k.a. Windows Digital Media Enhancements)Info: AddOn includes "Windows Audio Converter", "Windows CD Label Maker", "Windows Dancer" plus a few Screen Savers (all have been ported from XP Media Center. It does not include "Windows Party Mode" Jukebox or any of the crappy themes, I removed those.)MD5: 969C388AC31F11940D986FE52B638570Size: 16.9 MBDancers: http://www.microsoft.com/windowsxp/downloa...op/dancers.mspxHere is how its doneUse an Hex editor to change the bytes 74 08 to EB 00:CDLM.EXE: Offset 0xAED9DANCER.EXE: Offset 0x4DA9PARTYMODE.EXE: Offset 0x123E4DAVINCI.SCR: Offset 0x7F5EMYPIXDX.SCR: Offset 0x6B84NATURE.SCR: Offset 0x88F5AUDIOCONVERTER.EXE: Offset 0xEE5BWPGLDFSH.SCR: Offset 0xA4D9SPACE.SCR: Offset 0x75F3 Quote
runningfool Posted January 31, 2008 Posted January 31, 2008 woot, free screensavers!the space screensaver doesnt seem to be working...anyone else having any problems with this one? all i did was extract the addon and copy the screensavers to my system folder, so i might have screwed something up. Quote
ricktendo Posted January 31, 2008 Author Posted January 31, 2008 No me too, the space one only blinks but I thought it was jut me Maybe I will remove it along with Da Vinci because they arent that good anyhow (btw the space one even fails un-patched on MCE) Quote
runningfool Posted January 31, 2008 Posted January 31, 2008 rick, im gonna ask around some different forums and see if the space screensaver can somehow be fixed. im thinking its missing a .dll somewhere? i have a MCE conversion cd i got from demonoid that has these same files. ill check out the files on there to see if maybe the space screensaver is missing something.as for the da vinci...its working for me, but definitely does not look good. for now i would leave it in, just to be able to say all the MCE extras are included. Quote
MrNxDmX Posted February 1, 2008 Posted February 1, 2008 Sweet rick. Keep up the good work BTW, screen savers work ok for me. Quote
runningfool Posted February 1, 2008 Posted February 1, 2008 how did you get the space screensaver working??? Quote
MrNxDmX Posted February 1, 2008 Posted February 1, 2008 I did nothing as extra. Just installed the addon. Quote
TechnoHunter Posted March 1, 2008 Posted March 1, 2008 hey Rick? if you get a chance can you re-post this addon or update the link?seems to be missing unfortunatelythanks in advance! Quote
ricktendo Posted March 1, 2008 Author Posted March 1, 2008 OK I had mistakenly deleted it from FTP...try now. Quote
TechnoHunter Posted March 2, 2008 Posted March 2, 2008 nifty! thanks Rick, much obliged.TechnoHunter Quote
yadzil Posted March 5, 2008 Posted March 5, 2008 Hi Rick...great addon. I tried your addon but how can I confirm your addon installed? I check in my start menu programs list, plugIn list in windows media player and add and remove programs list but the program not listed. Quote
ricktendo Posted March 5, 2008 Author Posted March 5, 2008 Look for Windows Digital Media Enhancements in All Programs (you should see Dancers)Also adds a couple Screensavers Quote
dacorsa Posted March 9, 2008 Posted March 9, 2008 (edited) thanks! Edited March 9, 2008 by dacorsa Quote
soporific Posted March 19, 2008 Posted March 19, 2008 hey there,i don't see it installed and am too lazy to check if it is a SP3 issue by doing a test with SP2. Has anyone tried this with any release of SP3 and did it work?I'm trying it with SP3 v5503 and it's not happening.Cheers. Quote
hngovr1 Posted March 19, 2008 Posted March 19, 2008 hey there,i don't see it installed and am too lazy to check if it is a SP3 issue by doing a test with SP2. Has anyone tried this with any release of SP3 and did it work?I'm trying it with SP3 v5503 and it's not happening.Cheers.i couldnt even get it to work with SP2.... Quote
ricktendo Posted March 20, 2008 Author Posted March 20, 2008 Does it work on vista?I seriously doubt it Quote
jimmy Posted March 21, 2008 Posted March 21, 2008 (edited) a little off topic but is there anyway to get the wmp visualizations from the microsoft plus pack (almost the same stuff as the mce addons) to work on xp without installing the whole thing?i know when you try to register the .dll's it says you have to accept the ms agreement or something of that nature and won't register.i thought maybe there was a hex/reg hack that would get them to work.i can provide the files if someone interested.thanks in advance.p.s. thanks for the mce stuff for xp "ricktendo64" Edited March 21, 2008 by jimmy Quote
KsbjA Posted May 15, 2008 Posted May 15, 2008 Thanks ricktendo64, this is a great addition! Just wanted to ask if it works on SP3... Quote
Joe Member Posted May 18, 2008 Posted May 18, 2008 Does it work on vista?Yes, it is working on Windows Vista if you use compatible mode!!! Look at my Vista desktop: Quote
KsbjA Posted May 18, 2008 Posted May 18, 2008 Cool, but does this mean it will work on SP3? I mean, it would be weird, if it worked on all SPs of XP and Vista, EXCEPT SP3 on XP. Can somebody approve this? Quote
