Posted February 1, 200817 yr Ignore this program's name, because if you're a true Vista expert, you don't need it. But if you're like most people --- not tried-and-true Vista pros --- and don't know how to disable User Account Control, customize the menu power button, or disable or enable the Aero interface, then you'll want this program.This simple freebie makes it easy to customize many Vista features, via a simple interface. You'll be able to change the behavior of Windows Updates, User Account Control, the power button, Internet Explorer, and other Vista features. There's nothing big or dramatic here, but the program is free, and lets you easily customize Vista without having to dig through menus and dialog boxes, so it's worth a try.
February 1, 200817 yr Thanks Cro-Man, not a Vista user anymore but maybe when Win7 comes out they will have Vista fixed and I could use it then. LOL.
