Samkov Posted February 1, 2008 Posted February 1, 2008 hi i know theres software out there that makes your taskbar transparent, but is there software out there that makes your taskbar transparent but not your start button, cause the start button i designed looks very nice and when it is set transparent, the quality of it goes downusually none of my questions get answered, but if anyone knows please speak upthanks Quote
LUZR4LIFE Posted February 1, 2008 Posted February 1, 2008 usually none of my questions get answered, but if anyone knows please speak upI know how you feel. Unfortunately I don't know of any programs for that. Quote
Samkov Posted February 1, 2008 Author Posted February 1, 2008 ehhh alrite thanks m8, i guess any comment is better than no comment Quote
runningfool Posted February 1, 2008 Posted February 1, 2008 your best bet would be to find a theme that does this internally. and since youre looking for transparency, youll probably have to use windowblinds and mess with one of their transparent skins. but then again i know very little about making windows themes...or you could just do what i do and remove the taskbar completely O_o Quote
cro-man Posted February 1, 2008 Posted February 1, 2008 (edited) TitaniumTaskbarWith Titanium Taskbar (free) you will be able to make Windows Taskbar modifications.Here are some key features of "Titanium Taskbar": Edited February 1, 2008 by cro-man Quote
Samkov Posted February 1, 2008 Author Posted February 1, 2008 (edited) TitaniumTaskbarWith Titanium Taskbar (free) you will be able to make Windows Taskbar modifications.Here are some key features of "Titanium Taskbar": Edited February 1, 2008 by blind031 Quote
