Hello all, This is an unusual problem when i try to install my major drivers (graphics, mainboard etc) the setup just vanishes off the screen.
ASUS A8N5X
1GB RAM
Windows XP Pro - SP2
i've attached my files what i used for nlite, maybe someone can find the cause of the problem.
Thanks
It's 100% cause of nlite settings as recently tested
LAST_SESSION.TXT
LAST_SESSION_U.TXT
Edited by maly
Are you sure your WAREZ is not providing you with viruses too??
Thanks Kel you know what people are like once they hear "Warez" on these kind of forums.
...Obviously it's not WinRAR Extreme 100%
Edited by maly
You're very welcome. Don't bother asking for help when you are so blantantly using warez.
It's like rubbing s**t in our faces and then asking for help.
Out of Box Experience (OOBE)
Remote Installation Services (RIS)
Only remove OOBE if you have a VOL XP license (Known to cause issue otherwise)
Remote Installation Services (RIS) (Might be your issue)
Also you use ALOT of the tweaks and nLite has been known to have a couple of tweaks that don't work quite right.
Also can you extract the drivers and install them manually?
I've solved as of today, it was due to DEP "AlwaysON"
Thanks Kel for the advice i now wont remove RIS account
