Create static or animated cursors for Windows XP; make cursors from images.
Don't like the cursors that ship with Windows? Then create some of your own. It's a lot easier to do than you might think, with this free program. It will let you create and then use static cursors or animated cursors. You can edit your existing cursors, or create new ones from scratch. Especially useful is that you can also take any image, import it into the program, and the program then creates a cursor from it.
The program includes all the tools you'll need, and has several useful tutorials to help you get started. It even has links to an online cursor library where you can download free icons or complete icon sets that you can use as is, or else edit.
RealWorld Cursor Editor 2007.1 for Windows XP, Windows 2003, and Windows Vista
RealWorld Cursor Editor 2007.1 for 64-bit Windows
Thanks you
