Posted February 7, 200817 yr VirDir Manager 0.9 VirDir Manager helps you manage your system's files and folders more effectively. VirDir maps your favorite directory paths to drive letters, letting you access them quickly and easily. With VirDir you can easily eliminate having to deal with long directory pathshttp://www.digitalwidget.net/virdir/index.htmlMagicISO Virtual CD/DVD-ROMMagicDisc is freeware. It is very helpful utility designed for creating and managing virtual CD drives and CD/DVD discshttp://www.magiciso.com/tutorials/miso-mag...sc-overview.htmProperties PlusProperties Plus v1.65, is an Explorer shell extension that lets you modify file attributes, file extensions and time stamps by simply right-clickinghttp://cid-1e702eb0418cf6ad.skydrive.live....gy/pplus165.exeCachemanXPCachemanXP is a Windows tuneup utility designed to improve the speed and stability of your computer by optimizing caches, recovering RAM and fine tuning a number of system settings. Oneclick-Optimization makes it suitable for novice and intermediate users yet it is also powerful and versatile enough for computer experts. Backups of settings ensure that all user modifications can be reversed with a single click. CachemanXP requires Windows 2000/2003 or XP/XP64 to run, uses minimal resources and virtually no CPU timehttp://www.outertech.com/index.php?_charis...roduct&id=7I would be very grateful if some kind person could help me out with these.Thanx in advance :wub_anim:
February 7, 200817 yr I am working on some other request at the moment, if no one can get to theses when I finish the others I will try.
