lib9 Posted February 16, 2008 Posted February 16, 2008 hello everbody so the problem is when i try to replace shell32.res in V'ISO with my custum icon restorator don't accept it ??? and thanks for your helppicture: Quote
ricktendo Posted February 16, 2008 Posted February 16, 2008 Because you are probably trying to overwrite localized english icons with french ones. You may have to patch your french shell32.dll with the icons you want then export them in .res format using restorator Quote
lib9 Posted February 16, 2008 Author Posted February 16, 2008 i already translate shell32.res into french version ? anyway thanks i will use V'iso for patch my dll files and so one and replace it after by reshack . Quote
