hi since i switched to a x64 os ive had a slim pick for certain programs, such as AV, and Firewalls, anyways i finally found a x64 compatible antivirus: AVG free Ed. i do like it a lot, however it does give me a lot of false positives that i kno are legit programs, how do i add a program to the safe list so avg free dosent flag it as a trojan
thanks
Unfortunately AVG is very hard for a lot of users to configure. Does it prompt you or just delete the files?
yes it does, it says i can ignore it, but by the time i do the executable is cleaned out and will not even run
