tipu2185 Posted March 13, 2008 Posted March 13, 2008 I have been using this for some time, so I thought to share it. Replace files in EXE folder with already present in system32 folder using replacer.Please check before replacing that you have windows xp professional.You should have same version of files as given in archive i.e.ntkrnlmp.exe version 5.1.2600.3239ntkrnlpa.exe version 5.1.2600.3239ntkrpamp.exe version 5.1.2600.3239ntoskrnl.exe version 5.1.2600.3239Download Quote
MrNxDmX Posted March 14, 2008 Posted March 14, 2008 There is always hope Liked it. Thanks for share.May i release a turkish version under Wincert.net Turkish? Quote
tipu2185 Posted March 14, 2008 Author Posted March 14, 2008 (edited) There is always hope Liked it. Thanks for share.May i release a turkish version under Wincert.net Turkish?Yes sure why not. I have been using your IE7 addon for quite some time. I never knew that you were on deviant art as well . Actually I extract ryan's update pack and modify these four files and repack the archive to use it as an addon. I dont know how to make an addon other wise. If you want you can make an addon for boot screen as well. Edited March 14, 2008 by tipu2185 Quote
MrNxDmX Posted March 20, 2008 Posted March 20, 2008 (edited) How does this look I modified it a bit, yukleniyor means loading in turkish.Off-Topic Comment(Click to Show) shouldnt this topic be in windows customization?[Close]Edit: How can i edit the text in picture? "There is always hope" Edited March 22, 2008 by MrNxDmX Quote
tipu2185 Posted March 22, 2008 Author Posted March 22, 2008 There is always hope is embbed in picture means part of, so you have to use photoshop to edit picture. Quote
MrNxDmX Posted March 23, 2008 Posted March 23, 2008 Ok, one of my users did remove those text, now just need to write them in turkish again.I've released turkish addon here. Again, thanks a bunch Quote
efkan_37 Posted March 23, 2008 Posted March 23, 2008 Health which has become to her hands beautifully Quote
tipu2185 Posted March 24, 2008 Author Posted March 24, 2008 I like the other image to which was posted by a user in turkish thread but i dont understand turkish, I am pakistani, I can understand english , urdu and punjabi. I hope you succeed in your try. Best of luck Quote
