Posted January 3, 20241 yr When watching movies on a computer, subtitles can either save or ruin the fun, depending on their accuracy and the synchronization with the video. To make sure they get to read the lines the second they are uttered by the characters, users can edit the subtitles themselves using Subtitle Workshop. Subtitle Workshop is an advanced subtitle editor that integrates many other tools meant to lend users a hand in this regard. It includes a powerful spell checker and a well-organized interface that makes everything a lot easier. At first glance, Subtitle Workshop seems to be a bit more advanced version of a text editor, but it hides many very interesting features under its hood. For example, the nice and clean interface allows users to edit subtitles directly from the main window by double-clicking the line they wish to change. Plus, it provides a video preview window that gives a glimpse into the way the movie looks like with the modified subtitle. Subtitle Workshop has a spell checking feature, but it only works for users who have Microsoft Word installed on their PC. The program also includes a translation option which comes in handy for those who are not native speakers of English. More than that, Subtitle Workshop has all the functions needed to make subtitle editing a breeze. It supports configurable shortcuts, multi-language support, drag and drop, visual effects for subtitles and the option to mark text lines for later review. Another good thing is that the application is being delivered with a comprehensive help manual that provides basically all the info one needs to handle subtitles, so beginners should definitely have a look in there as well. As a conclusion, those looking for a smart app for subtitle editing jobs definitely need to take Subtitle Workshop into consideration. FEATURES • Supports converting between, creating, opening, editing, and saving over 60 (currently) subtitle formats via the Subtitle API library, as well as saving subtitles in a custom user-defined file format. • User-friendly, multi-language, customizable interface (including customizable shortcuts and translation mode). • Vast array of customizable tools and functions for automatic timing and text manipulations, including automatic durations, smart line adjusting, spell checking, FPS conversion, search and replace, and many more. • Comprehensive customizable system for automatically or manually detecting, marking, and fixing various timing and text subtitle errors. • Supports style tags (bold, italic, underline) and color tags in the subtitle text -- including full tags support for multiple tags in a single subtitle. • Supports displaying and manipulating the timing pauses (the time gap between two subtitles) and offers a CpS (Characters per Second) system. • Multi-level Undo-Redo system. • Integrated video player with customizable subtitles preview and full screen mode that would play any video or audio format the system has codecs installed for. • Offers various information about the subtitle file, including custom information based on user-defined rules about the timing or the text. • Supports the usage of external Pascal scripts, as well as find-and-replace text scripts (called OCR Scripts). Subtitle Editor derived from version 6.0b, but with UTF-8, audio stream selection, VLC support, Hunspell spellchecker and other improvements and extensions. Silent Silent installation Silent installation Quote https://www.mediafire.com/file/bzl5...orkshop+Classic+6.3.2+Silent+Install.rar/file https://mir.cr/1RHFOBVC الكاتب Edited September 9, 2024Sep 9 by 大†Shinegumi†大
March 1, 20241 yr Author 2024-02-28 (v6.2.9) Made the “Browse” button views in BatchConvert the same as the ‘Add’ view in the batch convert functionality, Reloading a movie file is not done any more after the same file is to be opened with Load Project, Load Subtitle or Recent file choice, Solved: Cancelling the “Load subtitle” modal window did reload the video for no reason, Solved: Moving subtitles around doesn’t analyze errors in the switched rows, which might lead to faulty error detections, Implemented: The Save subtitle button shouldn’t have three dots, as it doesn’t open any modal window or any subsequent part of any kind, The leading and trailing spaces in the search and replace strings are also saved now. Dark mode,
September 9, 2024Sep 9 Author # Subtitle-Workshop-Classic-v6.3.2 Subtitle Editor derived from version 6.0b, but with Audio waveform, UTF-8, audio stream selection, VLC support, Hunspell spellchecker and other improvements and extensions. 2024-09-08 (v6.3.2) Removed the '&' characters from the buttons on the 'Audio Waveform' window. Solved the background deviation in the errors window + the unreadable text, see https://sourceforge.net/p/subtitle-workshop-classic/discussion/general/thread/f7a7cf72f2/?limit=25#4acb Solved a problem in the info/error settings (prohibited chars a.o. were not saved correctly see https://sourceforge.net/p/subtitle-workshop-classic/discussion/general/thread/f7a7cf72f2/?limit=25#9d56/d2c2 Translation problem solved, part of https://sourceforge.net/p/subtitle-workshop-classic/discussion/general/thread/f7a7cf72f2/#ccf9 Hungarian translations and shortcuts added. Thanks Lassgabe, see https://sourceforge.net/p/subtitle-workshop-classic/discussion/general/thread/9d30136f0c/?limit=25#c47a ESC removed from shortcuts, made exit all windows (except Info/Errors), see https://sourceforge.net/p/subtitle-workshop-classic/discussion/general/thread/f7a7cf72f2/#8cc9 Added two sectences still to be translated (were forgotten in 6.3.1): [Error messages] 29=FFmpeg was not found in your system, please download it (menu Settings -> Settings -> Waveform -> Download FFmpeg tools). [Information messages] 24=No audio stream selected. Informations and errors window can no longer be closed with the Esc key now, see https://sourceforge.net/p/subtitle-workshop-classic/discussion/general/thread/f7a7cf72f2/?limit=25#8cc9/eaa7/a1e8 Improved: the Hunspell window stays on top now after error selection, see https://sourceforge.net/p/subtitle-workshop-classic/discussion/general/thread/f7a7cf72f2/?limit=25#8cc9/eaa7/a1e8 Corrected some accented shortcut texts that were displayed wrong in french (e.g. "duréé"). French shortcut texts tanslated now. English shortcut texts adapted. Added a 'preferred audio language' feature. Added extra text to be translated: [Settings form] PreferredAudio=Preferred audio language: Limited the maximum nr of entries in 'LastChoices' to the maximum set for 'recent' files. Solved a color problem with the subtitle sample in the Settings Video Preview subtitles. Language names in the Settings Language menu are now translated. Made some changes to the Expander/reducer window, see https://sourceforge.net/p/subtitle-workshop-classic/discussion/general/thread/f7a7cf72f2/?page=1&limit=25#f1c4/17ce/24ec/e18c/d77d and https://sourceforge.net/p/subtitle-workshop-classic/discussion/general/thread/f7a7cf72f2/?page=1&limit=25#f1c4/2220/14f5/3607/7d94 and https://sourceforge.net/p/subtitle-workshop-classic/discussion/general/thread/f7a7cf72f2/?page=2&limit=25#f1c4/2220/14f5/3607/7d94/fd0b/5c89 Made some layout changed in the "Set Delay" window due to a request, see https://sourceforge.net/p/subtitle-workshop-classic/discussion/general/thread/f7a7cf72f2/?page=1&limit=25#f1c4/17ce/24ec/e18c/d77d/41cb/1424/b4ad and https://sourceforge.net/p/subtitle-workshop-classic/discussion/general/thread/f7a7cf72f2/?page=1&limit=25#f1c4/17ce/24ec/e18c/d77d/41cb/1424/b4ad/0629/77d0 Solved a problem with space after characters, see https://sourceforge.net/p/subtitle-workshop-classic/discussion/bugs/thread/26d3820d6d/?limit=25#dd6f Made sure no audio streams are to be seen in menus when none are detected. Earlier on a erroneous list with default stream names was shown. UTF8 format is supported also from now on for language files and shortcut language files. Added item (e.g. for Dutch) to each language file: [General] Language=Nederlands to the language files: the translation of the language name in the actual language. The "join subtitles" and "Batch convert" functions now also allow dragging and dropping subtitle files to it. Organised a cache for the languagenames translations. It would take too much startup time to read all language files to obtain the translation. Solved a problem with Profile import, see https://sourceforge.net/p/subtitle-workshop-classic/discussion/general/thread/f7a7cf72f2/?page=2&limit=25#ceeb/28a4/825a Solved a problem after pressing OK in the settings window when the subtitle has not been save yet, see https://sourceforge.net/p/subtitle-workshop-classic/discussion/bugs/thread/da0ad2e2bc/?limit=25#195c/a487/3c47 Solved a problem: subtitle colors could not be changed, see https://sourceforge.net/p/subtitle-workshop-classic/discussion/bugs/thread/da0ad2e2bc/?limit=25#195c/a487/c098
