Posted March 14, 200817 yr Che dire ... INDISPENSABILE e unico funzionante.Ringaziamo il master di autoit per questo script.Stavolta io ho solo copiato, prima lo facevo a mano ...$Reg = FileOpenDialog("Choose a registry file", @ScriptDir, "Registry Files (*.reg)", 1)If @error = 1 Then Exit$Dir = StringLeft($Reg, StringInStr($Reg, '\', 0, -1) - 1)$NewReg = FileSaveDialog("Choose a file name", $Dir, "Scripts (*.au3)", 16)If @error = 1 Then ExitRunWait(@ComSpec & ' /c TYPE "' & $Reg & '" > "%TEMP%\' & GetFilename($Reg) & '"', @SystemDir, @SW_HIDE)$Reg = @TempDir & "\" & GetFilename($Reg)$OpenReg = FileOpen($Reg, 0)$OpenNewReg = FileOpen($NewReg, 2)Dim $KeyDim $valuenameGlobal $Oldvalue = ""$value = ""$Type = ""$Write = "Yes"$Continue1 = "No"$Continue2 = "No"$Continue3 = "No"$Line = FileReadLine($OpenReg, 2)$Line = ""While 1 $Line = FileReadLine($OpenReg) If @error Then ExitLoop If StringLeft($Line, 1) = ' ' Then $value = $Line If $Continue1 = "Yes" Then $Type = "REG_BINARY" If StringRight($value, 1) = "\" Then $value = StringTrimRight($value, 1) $Oldvalue = $Oldvalue & $value $Continue1 = "Yes" $Write = "No" Else $Oldvalue = $Oldvalue & $Line $Match1 = StringInStr($Oldvalue, ":") If $Match1 >= 1 Then $Oldvalue = StringTrimLeft($Oldvalue, $Match1) $value = StringReplace($Oldvalue, ",", "") $value = Chr(34) & StringStripWS($value, 8) & Chr(34) $Oldvalue = "" $Continue1 = "No" $Write = "Yes" EndIf ElseIf $Continue2 = "Yes" Then $Type = "REG_EXPAND_SZ" If StringRight($value, 1) = "\" Then $value = StringTrimRight($value, 1) $Oldvalue = $Oldvalue & $value $Continue2 = "Yes" $Write = "No" Else $Oldvalue = $Oldvalue & $Line $value = Chr(34) & CharsToString (StringStripWS($Oldvalue, 8)) & Chr(34) $Oldvalue = "" $Continue2 = "No" $Write = "Yes" EndIf ElseIf $Continue3 = "Yes" Then $Type = "REG_MULTI_SZ" If StringRight($value, 1) = "\" Then $value = StringTrimRight($value, 1) $Oldvalue = $Oldvalue & $value $Continue3 = "Yes" $Write = "No" Else $Oldvalue = $Oldvalue & $Line $value = Chr(34) & CharsToString (StringStripWS($Oldvalue, 8)) & Chr(34) $Oldvalue = "" $Continue3 = "No" $Write = "Yes" EndIf EndIf If $Write = "Yes" Then FileWrite($OpenNewReg, 'RegWrite("' & $Key & '", ' & $valuename & ', "' & $Type & '", ' & $value & ')' & @CRLF) EndIf If $Line <> "" Then Select Case StringLeft($Line, 1) = ";" FileWrite($OpenNewReg, $Line & @CRLF) Case StringLeft($Line, 1) = "[" If StringRight($Line, 1) = " " Then $Key = StringTrimRight($Line, 2) Else $Key = StringTrimRight($Line, 1) EndIf $Key = StringTrimLeft($Key, 1) If StringLeft($Key, 1) = "-" Then FileWrite($OpenNewReg, 'RegDelete("' & StringTrimLeft($Key, 1) & '")' & @CRLF) Case StringLeft($Line, 1) = '@' $value = StringTrimLeft($Line, 2) $value = StringReplace($value, '\\', '\') If Not StringLen($value) = 2 Then $value = StringReplace($value, '""', '"') If StringLeft($value, 1) = "-" Then FileWrite($OpenNewReg, 'RegDelete("' & $Key & '", "")' & @CRLF) Else FileWrite($OpenNewReg, 'RegWrite("' & $Key & '", "", "REG_SZ", ' & $value & ')' & @CRLF) EndIf Case StringLeft($Line, 1) = '"' $line_split = StringSplit($Line, "=") $valuename = $line_split[1] $value = $line_split[2] If StringInStr($value, 'hex:') >= 1 Then $Type = "REG_BINARY" If StringRight($value, 1) = "\" Then $value = StringTrimRight($value, 1) $Oldvalue = $value $Continue1 = "Yes" $Write = "No" Else $value = StringReplace($value, ",", "") $Match1 = StringInStr($value, ":") If $Match1 >= 1 Then $value = StringTrimLeft($value, $Match1) $value = Chr(34) & StringStripWS($value, 8) & Chr(34) $Continue1 = "No" $Write = "Yes" EndIf $Match1 = StringInStr($value, ":") If $Match1 >= 1 Then $value = StringTrimLeft($value, $Match1) ElseIf StringInStr($value, "hex(2):") >= 1 Then $Type = "REG_EXPAND_SZ" If StringRight($value, 1) = "\" Then $value = StringTrimRight($value, 1) $Oldvalue = $value $Continue2 = "Yes" $Write = "No" Else $value = Chr(34) & CharsToString (StringStripWS($value, 8)) & Chr(34) $Continue2 = "No" $Write = "Yes" EndIf ElseIf StringInStr($value, "hex(7)") >= 1 Then $Type = "REG_MULTI_SZ" If StringRight($value, 1) = "\" Then $value = StringTrimRight($value, 1) $Oldvalue = $value $Continue3 = "Yes" $Write = "No" Else $value = Chr(34) & CharsToString (StringStripWS($value, 8)) & Chr(34) $Continue3 = "No" $Write = "Yes" EndIf ElseIf StringLeft($value, 5) = "dword" Then $Type = "REG_DWORD" $value = StringTrimLeft($value, 6) If StringLeft($value, 1) = "0" Then For $i = 1 To StringLen($value) $Char = StringMid($value, $i, 1) If $Char <> "0" Then ExitLoop Next $value = StringTrimLeft($value, ($i - 1)) If $value = "" Then $value = "0" EndIf If StringLeft($value, 1) <> '"' And StringRight($value, 1) <> '"' Then $value = '"' & $value & '"' Else $Type = "REG_SZ" EndIf $value = StringReplace($value, '\\', '\') If Not StringLen($value) = 2 Then $value = StringReplace($value, '""', '"') If StringLeft($value, 1) = "-" Then FileWrite($OpenNewReg, 'RegDelete("' & $Key & '", ' & $valuename & ')' & @CRLF) Else If $Write = "Yes" Then FileWrite($OpenNewReg, 'RegWrite("' & $Key & '", ' & $valuename & ', "' & $Type & '", ' & $value & ')' & @CRLF) EndIf EndSelect Else FileWrite($OpenNewReg, @CRLF) EndIfWendFileClose($OpenNewReg)ExitFunc CharsToString ($Instring) Local $Match1 Local $Type $Match1 = StringInStr($Instring, ":") If $Match1 >= 1 Then $Instring = StringTrimLeft($Instring, $Match1) Dim $Temparray, $Count $Instring = StringReplace($Instring, " ", "") ;Remove trailing nulls While StringRight($Instring, 3) = ",00" $Instring = StringTrimRight($Instring, 3) Wend ;Create an array of character values and build string $Temparray = StringSplit($Instring, ",") $Instring = "" $x = 0 For $Count = 1 To $Temparray[0] If $Temparray[$Count] <> "00" Then $Instring = $Instring & Chr(Dec($Temparray[$Count]));convert hex to dec then get character value and append to return string $x = 0 Else $x = $x + 1 If $x = 3 Then $x = 0 $Instring = $Instring & '" & @LF & "' EndIf EndIf Next Return $InstringEndFuncFunc Debug ($message) Select Case $message = "#open" Opt ("WinTitleMatchMode", 2) Run("notepad") WinWait("Untitled", "") WinSetTitle("Untitled", "", "Debug Window") Case Else ControlSend("Debug Window", "", "Edit1", $message) EndSelectEndFunc ;==>DebugFunc GetFilename($Path) Local $TempArr Local $Filename $TempArr = StringSplit($Path, "\") If @error Then $Filename = $Path Else $Filename = $TempArr[UBound($TempArr) - 1] EndIf Return $FilenameEndFunc
