Posted (edited)
GMail Start Menu Shortcut Original Edition (Updated 09-25-2007)
MD5: AD47E42B7631323A2F17A603D632539E
Website: http://www.googlecityforums.com/blog/2005/...l-default-email
GMail Start Menu Shortcut ViStart Edition (Updated 09-25-2007)
WARNING: May cause false virus positive with some AV's
MD5: 452AC399E974C88C7701429DC12CA86C
Info: Both are now Uninstallable, if you don't use ViStart then I suggest you use the Original edition
If you want Google Mail set as your default mail client on 1st login, you may edit the following line in GMail.inf (remove the ";" semicolon)
;HKCU,"%MAIL%",,0,"%GMAIL%"
Edited by ricktendo64
  • 4 weeks later...
Hey Rick,
Well i installed this but it doesnt show up where its supposed to, is there any way to show up elsewhere like desktop or control pannel or just in the regular start -> All program (listings)
I think somewhere in nLite i have done something so it wont show..
Hoping you can help :)
ScOOt3r!
HMMM its supposed to show up at first boot in the place of outlook
Try right clicking on a blank space on the start menu and going into properties, now choose Customize and make sure the E-Mail box is checked and in the drop down menu tell me if you see Google Mail
Ok i got it working now, thanks Rick, this makes things easier:
FYI, i had to redo my settings in nLite for it to work, seems as if i blocked one of the settings.
ScOOt3r!
  • 9 months later...
Posted (edited)
:icon_question: Thanks Rick and yup it shows no Icon in ViStart. Any chance to fix this :icon_question:
Rick if I start Gmail from ViStart I get following error message :crying_anim02:
Edited by JurgenDoe
For some reason after using this gmail installer my rundll32.exe seems to be mest up now :crying_anim02:
WTF are you talking about?... NOTHING! is wrong with rundll32, its ViStart that doesn't know how to handle it.
Here is a Uninstaller if you want to fully get rid of it... Just Right Click on the INF and choose Install (yes INSTALL)
Obsolete...
Arg!!!... Thats probably because I used Quick Batch File converter to make a simple exe from a batch file, the reason is to make it compatible with ViStart.
Its a FALSE positive, but you can use the original if you want to use it still.
Its only a .ico file and some reg entries.
Updating now
