BAH
Page Not Found
We're sorry, the page you requested was not found. It is possible you typed the address incorrectly, or the page may no longer exist.
Please go back or return to the home page.
Thanks rick
I think I will add all your add on in my latest DVD now.
Sometimes I'm thinking about which one to choose ... But I think all deserve to be included... :)
  • 7 months later...
I happen to get a dll error after I reboot once this addon has been installed...Is this something related specifically to my system or the addon?
  • 3 months later...
i get this error after windows installation.
can you add that msvcp71.dll into Ricks_Rainlendar2.1_AddOn.rar and auto install to windows sistem?
  • 9 months later...
Rick I just stumbled across this, maybe update it in the future :type:
Using this with Google Calendar, works great :)
  • 4 weeks later...
ricktendo64, i would like some advice
so, i've been trying to create my own addon for Rainlendar v2.4 and i have run into a few snags.
1) how do you create an empty directory - from looking at your addon for v2.1, you use a runonce routine to that references the INF file again and executes a section that then executes a simple mkdir command - i get it. so why do you have to do it this way? why can't you insert the RunPostSetupCommands=Empty.Locale:1 command into the Rainlendar section and forego the need of the runonce routine. i tried it, it doesn't work but i don't know why it doesn't work
2) the settings file rainlendar2.ini are stored in %USERPROFILE%\.rainlendar2 - this is a double whammy - working with directories have names that start with a "." are an issue AND trying to get any sort of a directory into %USERPROFILE% or dirid 16424 seems to be impossible - any suggestions you might would be very helpful
RunPostSetupCommands only works if you launch the inf section using advpack.dll
You could use registerdlls (as a bonus it will hide the cmd window also)
RegisterDLLs=MakeDir
[MakeDir]
11,,cmd.exe,,,"/c md ""%16422%\Path"""
[MakeDir]
Ricktendo64, many thanks for the information, that and your suggestion helped immensely, now i just have to figure out how to get it posted for other peope's use. again, many thx, bfrg
