I want to change the icons on the left side of the start menu, currently I have outlook and firefox but I want to change outlook to Windows Live Mail, how can this be accomplished in a unattended setup ?
Also need to set Windows Live mail as default unattended ?
Thanks
EDIT:
I have figured it out, thanks to ricktendo64 :D
Well thanks tips !!!
I want to accomplish this unattended meaning after Windows XP has finished installing I will see Windows Live in the left side of the start menu and it is set as my default mail application.
EDIT:
I would also like to add I have done reg shots, compared them and added entries to my unattended setup but they make no change.
Thanks
EDIT:
I have the same problem... Need to set Windows Live mail as default unattended ?
Heyyy.....
I add this reg tweak to my main TWEAKS.REG file
; Add Windows Live mail to left side of start menu
[HKEY_CURRENT_USER\Software\Clients\mail]
@="Windows Live Mail"
not sure if that is the "proper" way but it works :)
