Hi kel,
WPI.exe you made me :D it did not work, I see you compiled it with quick batch so I did a little adjustment see below
for %%i in (D E F G H I J K L M N O P Q R S T U V W X Y Z) do if exist %%i:\wpi\wpi.hta set CDROM=%%i:
%cdrom%\WPI\WPI.hta
end
One problem which I have seen before but do not know how to fix, when I open the file I get Windows - No Disk Exception Processing Message, with a bunch of numbers.
Thank you
Posted (edited)
Sull
Try this
set tagfile=\WIN51
for %%i in (c d e f g h i j k l m n o p q r s t u v w x y z) do if exist "%%i:%tagfile%" set CDROM=%%i:
%CDROM%\wpi\wpi.hta
My code uses a file found on your windows disk called WIN51 and once found will then set CDROM to the drive letter and then runs the wpi.hta
Edited by Sm0k3r
No that made it worse, I now get the Windows - No Disk twice and have to click continue, WPI still opens but I would like to get rid of this.
PS. I did not compile with quick batch yet, just so you know...
Kel,
buddy I need your expertise, I have narrowed down this plug and play driver wizard issue ( I think ), problem is I have no idea what to do now. If I add everything to my CD except V'ISO and RunBox patcher I do not get the plug and play driver wizard, so I tried integrating V'ISO before integrating the driver packs and then I get the driver wizard, I took the runbox right out of the picture.
