Posted April 18, 200817 yr FileMenu Tools lets customize the context menu of the Windows Explorer. It lets configure the following aspects: * Add some build-in utilities in order to do operations over files and folders. * Add customized commands which let run external applications, copy/move to a specific folder or delete specific file types. * Configure the "Send to..." submenu. * Enable/disable the commands which are added by other applications to the context menu.ScrenshotsHomepage & Download
