good morning all the world I speak English well I how try change taskmgr.exe french colour in blue if it please you thank you
i've made a chinese one for myself using rick's blue addon, you may upload your taskmgr.exe somewhere and maybe i'll help you with it.
I've made an autoit script, and it works as well with the Italian taskmgr.exe. If you want to try it, just put in the same folder taskmgr.exe and this executable and then run it. That's it!
Note: Automatically it applies icons, bitmaps* and PEChecksum.
http://rapidshare.com/files/115008457/TaskMakr.exe
md5: B260A4D79A6B41EDBF9992C1EE6D90B1
filesize: 1,1 MB
*Edit: now it preserves local numbers of resources
Edited by kontini
Nice work indeed!
I've been struggling to do that via ResHacker but i've encountered some errors, dunno why maybe due to my idiocity.
That was what i intended to say if it worked. :(
Unfortunately this one still gives the same error, the CPU Usage part in this one too is not being displayed as it is in my case. Maybe it's due to the Turkish taskmgr.exe
Edited by Nomadturk
Thanks MrNxDmX, yours is working just great.
Kontini i just don't know why it didn't work with mine, it just doesn't display the CPU Usage part.
I don't know if it has something to do with me, i assume not.
FYI kontini; your exe worked perfect on my Turkish windows server 2008 taskmanager.exe file. All hex patched perfect :)
Edited by MrNxDmX
