can i create a Safely remove hardware Shortcut
Any one please reply
Yes, you can ...
Create a Shortcut to the Safely Remove Hardware Dialog
Create a Shortcut to immediately eject a specific drive, using a small freeware utility called USB Disk Ejector
Scrat
You can.
I've attached an example .lnk for you.
What you have to do is to create a new link, you should specify the program to be run as below.
RunDll32.exe shell32.dll,Control_RunDLL HotPlug.dll
Name it as you wish then save. After saving, right click, get in to properties and change the icon, load icon from file:
%windir%\system32\HotPlug.dll
Remove_Hardware.rar
