shahed Posted May 19, 2008 Posted May 19, 2008 hidoes anybody know any application similar to resource hacker, but with x64 binaries support. currently on x64 server 2008 (using as workstation), customized most of the themes and stuffs, but need a tool to modify the "shell32.dll and imageres.dll icons"thanks Quote
runningfool Posted May 20, 2008 Posted May 20, 2008 http://www.bome.com/Restorator/this is your one and only option... Quote
shahed Posted May 20, 2008 Author Posted May 20, 2008 http://www.bome.com/Restorator/this is your one and only option...thank you very much for the link. The app looks very good and easy to use.Thank you runningfool Quote
shahed Posted May 20, 2008 Author Posted May 20, 2008 hey runningfool, trust me you made my day. i can use restorator 2007 to modify anything specially the x64 binaries. i made my server 2008 x64 look better than vista.thank you so much :thumbsup_anim: Quote
runningfool Posted May 21, 2008 Posted May 21, 2008 create a 64-bit version of the XP Tango Patcher and youll make my YEAR: http://vertigosity.deviantart.com/art/Tang...7-08-2-27940418 Quote
shahed Posted May 21, 2008 Author Posted May 21, 2008 (edited) create a 64-bit version of the XP Tango Patcher and youll make my YEAR: http://vertigosity.deviantart.com/art/Tang...7-08-2-27940418will give it a shot, i dont think its going to be easy, because tango patcher patches huge amount of files, very time consuming, but will try to make one.Anyway thanks for your help on pointing out the perfect x64 resource editor (for me atleast) :thumbsup_anim: Edited May 21, 2008 by shahed Quote
Jared Posted February 12, 2010 Posted February 12, 2010 There is a new version 3.5.2 beta version of ResourseHacker that was posted on December 19th that supports 64bit. http://angusj.com/resourcehacker/Link Quote
